Salta al contenuto principale
Palm Pre Volume Button Replacement
Cosa ti serve
  1. Palm Pre Volume Button Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure your Palm Pre is turned off before disassembling the phone.
    • Snap off the back panel to reveal the battery.
  2. Palm Pre Volume Button Replacement: passo 2, immagine 1 di 1
    • Carefully pull up on the tab to remove the current battery.
    • Locate the volume cavity on the right of the back frame.
    • Take your new volume button and slide in into the slot until the opposite end clicks.
    • You will have to use some force to do so.
Conclusione
noha
Membro da: 04/12/12
139 Reputazione
6 Guide realizzate
Cal Poly, Team 7-31, Maness Spring 2012 Membro di Cal Poly, Team 7-31, Maness Spring 2012
CPSU-MANESS-S12S7G31
3 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 13
Tutti i Tempi: 298
