Parti
Nessuna parte richiesta.
Make sure your Palm Pre is turned off before disassembling the phone.
  • Make sure your Palm Pre is turned off before disassembling the phone.
  • Snap off the back panel to reveal the battery.
Aggiungi Commento
Carefully pull up on the tab to remove the current battery.
  • Carefully pull up on the tab to remove the current battery.
Aggiungi Commento
Use the t4 screwdriver to remove all 6 of the 3.6mm long screws. Use the t4 screwdriver to remove all 6 of the 3.6mm long screws.
  • Use the t4 screwdriver to remove all 6 of the 3.6mm long screws.
Aggiungi Commento
Use the spudger to locate the crease at the bottom of the keyboard. Carefully work your way around the phone separating the back frame from the keyboard.
  • Use the spudger to locate the crease at the bottom of the keyboard.
  • Carefully work your way around the phone separating the back frame from the keyboard.
Aggiungi Commento
Use tweezers to remove the DIV and GPS antennas from the back of the keyboard.
  • Use tweezers to remove the DIV and GPS antennas from the back of the keyboard.
Aggiungi Commento
Use the spuger to pry out the speaker. It is magnetically connected so do not be afraid to use the necessary force.
  • Use the spuger to pry out the speaker. It is magnetically connected so do not be afraid to use the necessary force.
    • Make sure to take note of the orientation of the speaker for re-installation.
    • Make sure not the puncture the screen on the outside of the back frame.
Aggiungi Commento
Conclusione
noha
Membro da: 12/04/2012
139 Reputazione
12 Guide realizzate
Cal Poly, Team 7-31, Maness Spring 2012 Membro di Cal Poly, Team 7-31, Maness Spring 2012
CPSU-MANESS-S12S7G31
3 Membri
16 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,051
