Salta al contenuto principale
Palm Pilot Professional 3com Plastic Frame Replacement
Cosa ti serve
  1. Palm Pilot Professional 3com Plastic Frame Replacement, Keypad: passo 1, immagine 1 di 1
    • Unscrew the three screws on the back of the Palm Pilot.
  2. Palm Pilot Professional 3com Plastic Frame Replacement: passo 2, immagine 1 di 2 Palm Pilot Professional 3com Plastic Frame Replacement: passo 2, immagine 2 di 2
    • Pull the back cover from the bottom of the device and separate the interlocking tabs on the top to remove the back cover.
  3. Palm Pilot Professional 3com Plastic Frame Replacement: passo 3, immagine 1 di 1
    • The front plastic cover is now free to be removed from the rest of the device.
  4. Palm Pilot Professional 3com Plastic Frame Replacement: passo 4, immagine 1 di 1
    • The keypad is now free to be removed from the rest of the device.
  5. Palm Pilot Professional 3com Plastic Frame Replacement, LCD Screen: passo 5, immagine 1 di 1
    • Looking at the back of the device hold one of the white tabs on the ribbon cable connector down and use tweezers to push in the other white tab toward the device at the same time.
  6. Palm Pilot Professional 3com Plastic Frame Replacement: passo 6, immagine 1 di 1
    • The ribbon cable is now loose. Use the tweezers to carefully slide the ribbon cable out of the connector.
  7. Palm Pilot Professional 3com Plastic Frame Replacement: passo 7, immagine 1 di 2 Palm Pilot Professional 3com Plastic Frame Replacement: passo 7, immagine 2 di 2
    • The screen is now disconnected from the rest of the device and can now be removed.
  8. Palm Pilot Professional 3com Plastic Frame Replacement, Plastic Frame: passo 8, immagine 1 di 2 Palm Pilot Professional 3com Plastic Frame Replacement, Plastic Frame: passo 8, immagine 2 di 2
    • Depress the tabs around the battery casing so that the battery casing can slide through the rectangular slot on the motherboard - opposite of the metal plate.
  9. Palm Pilot Professional 3com Plastic Frame Replacement: passo 9, immagine 1 di 2 Palm Pilot Professional 3com Plastic Frame Replacement: passo 9, immagine 2 di 2
    • Pull/push the battery casing through the rectangular opening. The mother board should now separate from the plastic frame.
    • Note: The frame might have to be wiggled towards the left (when the springs are facing left) to become fully released.
Conclusione
Kevin Santos
Membro da: 03/09/12
1 Reputazione
4 Guide realizzate
Clemson, Team 2-4, Benson Spring 2012 Membro di Clemson, Team 2-4, Benson Spring 2012
CLEM-BENSON-S12S2G4
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 860
