Parti
Nessuna parte richiesta.
Push in the button at the bottom of the phone, and lift the back cap off.
  • Push in the button at the bottom of the phone, and lift the back cap off.
Aggiungi Commento
Remove the battery by pulling out the little tab.
  • Remove the battery by pulling out the little tab.
Aggiungi Commento
Turn phone over on its left side and remove single phillip's head screw using the Phillips #0 screwdriver.
  • Turn phone over on its left side and remove single phillip's head screw using the Phillips #0 screwdriver.
Aggiungi Commento
After screw is removed take the plastic opening tool and apply slight pressure to even out bends in the metal
  • After screw is removed take the plastic opening tool and apply slight pressure to even out bends in the metal
Aggiungi Commento
Insert charger to check adjustments to metal outlet
  • Insert charger to check adjustments to metal outlet
Aggiungi Commento
Conclusione
ironwill13791
Membro da: 30/10/2013
509 Reputazione
10 Guide realizzate
UMass Dartmouth, Team 2-2, Gulbrandsen Fall 2013 Membro di UMass Dartmouth, Team 2-2, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S2G2
3 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 158
