Introduzione
Removing the batteries is a very simple process that is also a preliminary step to gaining access to the inside of the device.
Turn the device over so it is face down and remove the stylus, and battery cover. Turn the device over so it is face down and remove the stylus, and battery cover. Turn the device over so it is face down and remove the stylus, and battery cover.
  • Turn the device over so it is face down and remove the stylus, and battery cover.
Aggiungi Commento
Now remove the two batteries by pulling on the cloth black tab. Remember, when inserting the batteries, to keep the tab below them to make it easier to remove the batteries in the future.
  • Now remove the two batteries by pulling on the cloth black tab.
    • Remember, when inserting the batteries, to keep the tab below them to make it easier to remove the batteries in the future.
  • If this tab is not visible, use the flat head screwdriver and gently pry out the batteries by pushing on the positive end (opposite the spring).
Aggiungi Commento
Conclusione
Jacob
Membro da: 15/04/2010
1 Reputazione
3 Guide realizzate
Cal Poly, Team 16-1, Maness Spring 2010 Membro di Cal Poly, Team 16-1, Maness Spring 2010
CPSU-MANESS-S10S16G1
4 Membri
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,543
