Introduzione
A guide to replace a damaged or cracked screen.
Place the Palm IIIx face down on a flat surface.
  • Place the Palm IIIx face down on a flat surface.
Aggiungi Commento
Push down, lift up on, and remove battery cover.
  • Push down, lift up on, and remove battery cover.
Aggiungi Commento
Remove the old batteries one at a time.
  • Remove the old batteries one at a time.
Aggiungi Commento
Using a Phillips #00 screwdriver, remove the four screws that hold the back cover in place.
  • Using a Phillips #00 screwdriver, remove the four screws that hold the back cover in place.
Aggiungi Commento
Hold the device on its side, positioning your hands as shown.
  • Hold the device on its side, positioning your hands as shown.
  • Remove the back cover by pushing in with your thumbs and pulling outward with the rest of your fingers.
Aggiungi Commento
Hold the screen and front cover on its side, facing the screen inward as shown.
  • Hold the screen and front cover on its side, facing the screen inward as shown.
  • Position your hands so that you can push the screen outward with your thumbs.
  • Remove the screen by pushing outward with your thumbs. Use your index fingers to hold the front cover in place.
Aggiungi Commento
Position the device with the screen facing down. Locate the white ribbon wire on the left hand side of the device.
  • Position the device with the screen facing down.
  • Locate the white ribbon wire on the left hand side of the device.
  • On either side of the ribbon wire are two white clasps. Gently push the two clasps away from the board (to the left).
Aggiungi Commento
Detach the ribbon wire by gently pulling it out of its connector.
  • Detach the ribbon wire by gently pulling it out of its connector.
Aggiungi Commento
Separate the motherboard from the screen.
  • Separate the motherboard from the screen.
Aggiungi Commento
On the back of the screen near the top right corner is a plastic filament: Gently lift up on the two brown clasps on either side of the filament connector as shown.
  • On the back of the screen near the top right corner is a plastic filament:
    • Gently lift up on the two brown clasps on either side of the filament connector as shown.
    • Using a thin, blunt object (a toothpick works well), slide it under the plastic filament and lift up to detach the filament from its connector.
Aggiungi Commento
Insert a spudger tool between the metal backing and the glass cover piece, as shown.
  • Insert a spudger tool between the metal backing and the glass cover piece, as shown.
  • Run the spudger along the edge of the screen until the screen is lifted and can be removed.
  • Replace or clean as needed.
Aggiungi Commento
Conclusione
David Haskell
Membro da: 21/01/2010
44 Reputazione
3 Guide realizzate
Cal Poly, Team 14-43, Regan Winter 2010 Membro di Cal Poly, Team 14-43, Regan Winter 2010
CPSU-REGAN-W10S14G43
5 Membri
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,086
