Salta al contenuto principale
Palm IIIx Front Button Cluster Replacement
Cosa ti serve
  1. Palm IIIx Front Button Cluster Replacement, Battery: passo 1, immagine 1 di 1
    • Place the Palm IIIx face down on a flat surface.
  2. Palm IIIx Front Button Cluster Replacement: passo 2, immagine 1 di 1
    • Push down and lift up the battery cover to remove it.
  3. Palm IIIx Front Button Cluster Replacement: passo 3, immagine 1 di 1
    • Remove the old batteries one at a time.
  4. Palm IIIx Front Button Cluster Replacement, Front Button Cluster: passo 4, immagine 1 di 1
    • Using a Phillips #00 screwdriver, remove the four screws that hold the back cover in place.
  5. Palm IIIx Front Button Cluster Replacement: passo 5, immagine 1 di 1
    • Hold the device on its side, positioning your hands as shown.
    • Remove the back cover by pushing in with your thumbs and pulling outward with the rest of your fingers
  6. Palm IIIx Front Button Cluster Replacement: passo 6, immagine 1 di 1
    • Hold the screen and front cover in a vertical position, facing the screen inward, as shown.
    • Position your hands so you can push the screen outward with your thumbs.
    • Remove the front cover by gently pushing outward with your thumbs. Use your index fingers to pull back on the front cover.
  7. Palm IIIx Front Button Cluster Replacement: passo 7, immagine 1 di 1
    • Remove cluster by pulling on the rubber backing.
    • Clean, repair, and/or replace as neccessary.
Conclusione
Cal Poly, Team 14-43, Regan Winter 2010 Membro di Cal Poly, Team 14-43, Regan Winter 2010
CPSU-REGAN-W10S14G43
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,332
