Introduzione
Follow this guide to remove and replace your Palm IIIc's motherboard.
Parti
Nessuna parte richiesta.
Keep track of all pieces removed from the device.
  • Keep track of all pieces removed from the device.
  • Gently pull off the device cover. The cover snaps on and off easily where the cover attaches to the Palm IIIc device
Aggiungi Commento
Using a Phillips head screw driver, take out the four screws on the back of the device. You may have to pull them out with your hands once they are unscrewed.
  • Using a Phillips head screw driver, take out the four screws on the back of the device. You may have to pull them out with your hands once they are unscrewed.
  • There will be two long screws and two short screws. The long screws come from the top of the device, and the short screws come from the bottom of the device.
Aggiungi Commento
Using a spudger, carefully pry open the front and back covers along the side seam.
  • Using a spudger, carefully pry open the front and back covers along the side seam.
  • A small sensor cover will fall out when the front and back covers are removed. Keep track of it.
Aggiungi Commento
Screen-side down, unhook the battery cable from the motherboard.
  • Screen-side down, unhook the battery cable from the motherboard.
Aggiungi Commento
Unhook the blue and red screen cables. Unhook the blue and red screen cables.
  • Unhook the blue and red screen cables.
Aggiungi Commento
On the back of the motherboard near the top, gently lift up the flap that holds the ZIF connector tab in place. This will allow you to pull out the ZIF connector tab. On the back of the motherboard near the top, gently lift up the flap that holds the ZIF connector tab in place. This will allow you to pull out the ZIF connector tab.
  • On the back of the motherboard near the top, gently lift up the flap that holds the ZIF connector tab in place. This will allow you to pull out the ZIF connector tab.
Aggiungi Commento
Located near the bottom of the motherboard will be two ZIF connector tabs. Gently lift up the flap that secures these tabs and remove the tabs. Located near the bottom of the motherboard will be two ZIF connector tabs. Gently lift up the flap that secures these tabs and remove the tabs. Located near the bottom of the motherboard will be two ZIF connector tabs. Gently lift up the flap that secures these tabs and remove the tabs.
  • Located near the bottom of the motherboard will be two ZIF connector tabs. Gently lift up the flap that secures these tabs and remove the tabs.
Aggiungi Commento
Gently bend back the black clips that secure the motherboard.
  • Gently bend back the black clips that secure the motherboard.
  • Remove the motherboard starting from the left side and pull it out away from the clips.
Aggiungi Commento
Conclusione
Paulina Trujillo
Membro da: 07/04/2011
241 Reputazione
9 Guide realizzate
Cal Poly, Team 20-69, Walters Spring 2011 Membro di Cal Poly, Team 20-69, Walters Spring 2011
CPSU-WALTERS-S11S20G69
5 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 997
