Salta al contenuto principale
Palm Centro Keyboard Replacement
Cosa ti serve
  1. Palm Centro Keyboard Replacement, Disassembling Palm Centro Battery: passo 1, immagine 1 di 2 Palm Centro Keyboard Replacement, Disassembling Palm Centro Battery: passo 1, immagine 2 di 2
    • Press and slide open the battery cover.
  2. Palm Centro Keyboard Replacement: passo 2, immagine 1 di 1
    • Caution: Turn cell phone off before removing battery!
    • Press battery to the right.
    • Then lift up battery pack to remove.
  3. Palm Centro Keyboard Replacement: passo 3, immagine 1 di 1
    • Phone with battery removed
  4. Palm Centro Keyboard Replacement, Back Housing: passo 4, immagine 1 di 1
    • Remove the touchpad pen from the top left corner on the back to reveal the last of 6 screws to be removed.
  5. Palm Centro Keyboard Replacement: passo 5, immagine 1 di 1
    • Lift the rubber cap at the top right to reveal the sixth screw.
    • Caution: There is a small Palm sticker under the rubber cap. Tampering with or removing this sticker will void your warranty!
    • Remove the six screws using the T5 Torx screwdriver.
  6. Palm Centro Keyboard Replacement: passo 6, immagine 1 di 2 Palm Centro Keyboard Replacement: passo 6, immagine 2 di 2
    • Remove the SIM card so housing can be separated.
  7. Palm Centro Keyboard Replacement: passo 7, immagine 1 di 2 Palm Centro Keyboard Replacement: passo 7, immagine 2 di 2
    • Use a plastic pry tool to separate the bottom of the case to remove the small plastic insert.
  8. Palm Centro Keyboard Replacement: passo 8, immagine 1 di 2 Palm Centro Keyboard Replacement: passo 8, immagine 2 di 2
    • Remove the small plastic insert at the bottom of the phone.
  9. Palm Centro Keyboard Replacement: passo 9, immagine 1 di 2 Palm Centro Keyboard Replacement: passo 9, immagine 2 di 2
    • Continue with plastic pry tool all the way around the phone to remove the back housing.
  10. Palm Centro Keyboard Replacement, Logic Board: passo 10, immagine 1 di 1
    • Carefully peel back the tape holding the speaker (left) and keyboard (right) connection tabs in place.
  11. Palm Centro Keyboard Replacement: passo 11, immagine 1 di 1
    • Using the plastic prying tool, lift the tabs and carefully pull the contact connections out on both sides.
    • Be very careful, these electronics are delicate!
  12. Palm Centro Keyboard Replacement: passo 12, immagine 1 di 1
    • Separate the logic board from the case by lifting and pulling out the bottom.
  13. Palm Centro Keyboard Replacement, Screen: passo 13, immagine 1 di 1
    • Slowly peel off the protective lining that is on the screen and keyboard.
  14. Palm Centro Keyboard Replacement: passo 14, immagine 1 di 2 Palm Centro Keyboard Replacement: passo 14, immagine 2 di 2
    • Lift and slowly remove the screen from the front panel
    • Place the new screen into the front panel
    • Make sure the new screen goes in under the plastic tabs for the additional memory slot door or it may not close properly once the phone is put back together.
  15. Palm Centro Keyboard Replacement, Keyboard: passo 15, immagine 1 di 1
    • Now that the screen is out and its electrical ribbon is not in the way, you can remove the keyboard by prying it free of the tabs that hold it in place.
Conclusione
Jordan Coenen
Membro da: 04/19/10
210 Reputazione
1 Guida realizzata
Cal Poly, Team 15-49, Garner Spring 2010 Membro di Cal Poly, Team 15-49, Garner Spring 2010
CPSU-GARNER-S10S15G49
5 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 18
Tutti i Tempi: 4,011
