Salta al contenuto principale
PSP Go Bottom Plate Replacement
Cosa ti serve
  1. PSP Go Bottom Plate Replacement, Back Cover: passo 1, immagine 1 di 2 PSP Go Bottom Plate Replacement, Back Cover: passo 1, immagine 2 di 2
    • Unscrew the four Phillips screws on the back of the PSP Go.
    • Rotate the PSP so you can see the top of the device.
    • Unscrew the two Phillips screws next to the volume buttons.
  2. PSP Go Bottom Plate Replacement: passo 2, immagine 1 di 2 PSP Go Bottom Plate Replacement: passo 2, immagine 2 di 2
    • Use a plastic opening tool around the perimeter of the back cover to loosen it on all sides.
    • Open the back cover by gently lifting the right side, and rotating it to the left side (as if you were opening a book).
    • Be careful not to rotate the back cover from the bottom, as you will break the plastic screw holes on top of the device.
  3. PSP Go Bottom Plate Replacement, Top Cover: passo 3, immagine 1 di 1
    • Pull the top cover upwards gently from its housing.
  4. PSP Go Bottom Plate Replacement, Bottom Plate: passo 4, immagine 1 di 2 PSP Go Bottom Plate Replacement, Bottom Plate: passo 4, immagine 2 di 2
    • Remove the two Phillips screws holding the bottom plate.
    • Gently lift the bottom plate away from the device.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 10
Tutti i Tempi: 7,211
