Introduzione
Did you drop your PSP? If your LCD is broken for any reason, you're in luck! This guide will show you how to replace that LCD with a brand new one.
Press the button securing the battery door to the PSP 300xc, and lift the battery door off. Lift the battery out of the PSP.
  • Press the button securing the battery door to the PSP 300xc, and lift the battery door off.
  • Lift the battery out of the PSP.
Aggiungi Commento
Use a spudger or your fingernail to remove the warranty sticker stuck to the inside of the battery tray
  • Use a spudger or your fingernail to remove the warranty sticker stuck to the inside of the battery tray
Aggiungi Commento
Remove four Phillips screws from the back of the PSP. Remove four Phillips screws from the back of the PSP.
  • Remove four Phillips screws from the back of the PSP.
Aggiungi Commento
Remove two Phillips screws from the top of the PSP.
  • Remove two Phillips screws from the top of the PSP.
Aggiungi Commento
Remove a single screw from the bottom edge of the PSP.
  • Remove a single screw from the bottom edge of the PSP.
Aggiungi Commento
Insert a spudger between the front case and PSP, and slide the spudger along the perimeter of the front case to remove it. Insert a spudger between the front case and PSP, and slide the spudger along the perimeter of the front case to remove it.
  • Insert a spudger between the front case and PSP, and slide the spudger along the perimeter of the front case to remove it.
Aggiungi Commento
Remove a single Phillips screw securing the home bar to the PSP 300xc.
  • Remove a single Phillips screw securing the home bar to the PSP 300xc.
Aggiungi Commento
Push the home bar to the right about 1cm to release a tab, and begin to lift the right end of the home bar slightly. Do not attempt to remove the home bar yet, it is still attached to the PSP 300xc.
  • Push the home bar to the right about 1cm to release a tab, and begin to lift the right end of the home bar slightly.
  • Do not attempt to remove the home bar yet, it is still attached to the PSP 300xc.
Aggiungi Commento
Insert a spudger under the LCD, beside the black plastic tab.
  • Insert a spudger under the LCD, beside the black plastic tab.
  • Push the LCD to the left and pry up to release the left edge of the LCD from under the plastic tab.
Aggiungi Commento
  • Push the LCD to the right and pry up to release the right edge of the LCD from under the plastic tab.
Aggiungi Commento
Rotate the LCD away from the PSP to reveal the LCD and home bar ribbon cables. Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following four ZIF connectors: Home bar cable
  • Rotate the LCD away from the PSP to reveal the LCD and home bar ribbon cables.
  • Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following four ZIF connectors:
    • Home bar cable
    • Microphone cable
    • LCD display data cable
    • Touchscreen cable
  • Be sure you are prying up on the retaining flap, not the socket itself
  • After flipping up the locking tabs on all four connectors, use your fingers or a spudger to gently pull the cables straight out of the connectors.
Aggiungi Commento
Remove the LCD from the PSP 300xc.
  • Remove the LCD from the PSP 300xc.
Aggiungi Commento
Conclusione
Altre 10 persone hanno completato questa guida.
Matthew Newsom
Membro da: 05/01/2010
31.477 Reputazione
93 Guide realizzate
the metal bar on the lcd of the revisioned 3000 is easily removable with a spudger while the first gen 3000s have metal bars like 2000s, repairing any psp 3000 brite units is the easiest one to repair among the 4 other models of psp
Ghost - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 14
Tutti i Tempi: 3,600
