Salta al contenuto principale
PSP 300x D-Pad Replacement
Cosa ti serve
  1. PSP 300x D-Pad Replacement, Battery: passo 1, immagine 1 di 3 PSP 300x D-Pad Replacement, Battery: passo 1, immagine 2 di 3 PSP 300x D-Pad Replacement, Battery: passo 1, immagine 3 di 3
    • Place the PSP face down and locate the battery cover on the left side of the device.
    • Lift and remove the battery cover to reveal the battery.
    • Remove the battery.
  2. PSP 300x D-Pad Replacement, Casing: passo 2, immagine 1 di 1
    • Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
  3. PSP 300x D-Pad Replacement: passo 3, immagine 1 di 2 PSP 300x D-Pad Replacement: passo 3, immagine 2 di 2
    • Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver.
    • Two are located behind the battery's warranty sticker.
    • Two are located on the right side of the PSP.
  4. PSP 300x D-Pad Replacement: passo 4, immagine 1 di 1
    • Next, unscrew the two screws located at the top of the PSP.
  5. PSP 300x D-Pad Replacement: passo 5, immagine 1 di 1
    • Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
  6. PSP 300x D-Pad Replacement: passo 6, immagine 1 di 2 PSP 300x D-Pad Replacement: passo 6, immagine 2 di 2
    • Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
    • Remove the front casing completely.
  7. PSP 300x D-Pad Replacement, D-Pad: passo 7, immagine 1 di 2 PSP 300x D-Pad Replacement, D-Pad: passo 7, immagine 2 di 2
    • Peal up the rubber pad that is securing the D-pad buttons to the backside of the front casing.
    • Remove the D-pad and the rubber piece.
Conclusione
Altre 4 persone hanno completato questa guida.
mbnewsom
Membro da: 10/28/09
3.103 Reputazione
11 Guide realizzate
Un commento
Is it for 2000?
Kaio Igor - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 30
Ultimi 30 Giorni: 113
Tutti i Tempi: 9,322
