Introduzione
Steps for replacing the outer casing of a Sony PSP-3000.
Place the PSP face down and locate the battery cover on the left side of the device. Lift and remove the battery cover to reveal the battery. Remove the battery.
  • Place the PSP face down and locate the battery cover on the left side of the device.
  • Lift and remove the battery cover to reveal the battery.
  • Remove the battery.
Aggiungi Commento
Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
  • Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
Aggiungi Commento
Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver. Two are located behind the battery's warranty sticker.
  • Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver.
    • Two are located behind the battery's warranty sticker.
    • Two are located on the right side of the PSP.
Aggiungi Commento
Next, unscrew the two screws located at the top of the PSP.
  • Next, unscrew the two screws located at the top of the PSP.
Aggiungi Commento
Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
  • Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
Aggiungi Commento
Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
 Remove the front casing completely.
  • Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
  • Remove the front casing completely.
Aggiungi Commento
Conclusione
Altre 16 persone hanno completato questa guida.
kbrunner
Membro da: 05/11/2009
26 Reputazione
1 Guida realizzata
Cal Poly, Team 19-2, Maness Fall 2009 Membro di Cal Poly, Team 19-2, Maness Fall 2009
CPSU-MANESS-F09S19G2
3 Membri
2 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 86
Tutti i Tempi: 6,559
