Introduzione
A common issue for the PSP is the UMD door becoming shaky or loose. This guide will show you how to maintain or repair the UMD door.
Cosa ti serve
The Button Board, at the base of the LCD Screen, is held by two clips.
Pry these clips over the nubs using a PSP opening tool. This will release the clips.
The thin Ribbon Cable opens from the opposite side in which the Ribbon Cable enters. Open up the latch towards the Ribbon Cable. The latch will pull up and release the ribbon cable. Put your tool behind the black part, then pry up the black piece of plastic.
The wide Ribbon Cable opens from the same side in which the Ribbon Cable attatches, and opens away from the cable.
Both of these latches are the black pieces.
Gently pull the ribbon cables away from the latches. The LCD screen can now be removed.
Because the problem was that the door was loose, clean all parts of dirt or debris.
Align the tray to the 2 hinges at the bottom and slide the tray to the left, back into place. The latch should still be above the UMD frame.
Apply light pressure to the left side while lowering the tray to its original position.
This next part is a bit tricky. Notice the slot for the spring arm and the slot for the UMD tray in the the corners.
Turn the PSP upside-down, so that the bottom is now facing up.
First slide the UMD tray into the slots on the UMD cover. Once these are in, align the spring into its slot.
Altre 36 persone hanno completato questa guida.
4 Commenti
Hi, my UMD door opens too easily, just as i touch it sometimes, and i have to press it hard to close it. What should i do to make it stay close? i don’t understand why it has become so loose
You can actually use a file and an exacto knife and some sandpaper on an aftermarket door. They tried to make an L-shaped reinforcement on the right side (if looking at the PSP from the back) that's why it's quite hard to get it in past those screws, just shave and file and sliver little by little, until it fits in without even having to take off the front case. You may also have to do some trimming and gluing of the latch catch on most of these aftermarket UMD doors.
