Salta al contenuto principale
PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement
Cosa ti serve
  1. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement, Joysticks: passo 1, immagine 1 di 1
    • Remove the two 11 mm screws from the back of the controller using a Phillips #0 screwdriver.
    • Remove the five 8 mm screws from the back of the controller using a Phillips #0 screwdriver.
  2. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: passo 2, immagine 1 di 1
    • Remove the back cover from the controller and set it aside.
  3. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: passo 3, immagine 1 di 1
    • Remove the circuit board from the front casing.
    • Be cautious of disconnecting the vibration motors which are attached by thin wires.
  4. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: passo 4, immagine 1 di 3 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: passo 4, immagine 2 di 3 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: passo 4, immagine 3 di 3
    • Wiggle and pull the joystick until it comes off of the circuit board.
  5. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: passo 5, immagine 1 di 2 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: passo 5, immagine 2 di 2
    • Place the new joystick into position and press until the joystick makes a click.
  6. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: passo 6, immagine 1 di 1
    • Place the circuit board and vibration motors back into the front casing.
  7. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: passo 7, immagine 1 di 3 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: passo 7, immagine 2 di 3 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: passo 7, immagine 3 di 3
    • Place the back cover into position.
    • Reinsert the two 11 mm screws into the back of the controller using a Phillips #0 screwdriver.
    • Reinsert the five 8 mm screws into the back of the controller using a Phillips #0 screwdriver.
Linea Traguardo
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 73
Tutti i Tempi: 2,642
