Salta al contenuto principale
Oster 6329 Outer Shell Removal
Cosa ti serve
  1. Oster 6329 Outer Shell Removal, Outer Shell Removal: passo 1, immagine 1 di 2 Oster 6329 Outer Shell Removal, Outer Shell Removal: passo 1, immagine 2 di 2
    • Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
  2. Oster 6329 Outer Shell Removal: passo 2, immagine 1 di 1
    • Push the plastic push-down handle down and pull the plastic handle straight from metal arm.
  3. Oster 6329 Outer Shell Removal: passo 3, immagine 1 di 1
    • Loosen the outer metal shell from the plastic base by holding the plastic base while pulling up on the metal shell.
    • Only lift the outer shell a little so as not to disconnect the cables that connect the circuit board.
  4. Oster 6329 Outer Shell Removal: passo 4, immagine 1 di 2 Oster 6329 Outer Shell Removal: passo 4, immagine 2 di 2
    • Disconnect the cable clips from the circuit board using the tweezers to free the outer metal shell from the plastic base.
  5. Oster 6329 Outer Shell Removal: passo 5, immagine 1 di 2 Oster 6329 Outer Shell Removal: passo 5, immagine 2 di 2
    • Lift the top outer metal shell.
    • Carefully lift the outer metal shell at an angle so as not to damage the components in the front of the toaster.
Conclusione
Cal Poly, Team 13-15, Regan Winter 2014 Membro di Cal Poly, Team 13-15, Regan Winter 2014
CPSU-REGAN-W14S13G15
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 33
Tutti i Tempi: 1,923
