Remove the Blender Container from the Blender Base. Remove the Blender Container from the Blender Base.
  • Remove the Blender Container from the Blender Base.
Aggiungi Commento
Flip the blender so the bottom is facing you. Flip the blender so the bottom is facing you.
  • Flip the blender so the bottom is facing you.
Aggiungi Commento
Unscrew the 16mm screws located on the plastic bottom from the blender base using a Phillips #2 screwdriver. Unscrew the 16mm screws located on the plastic bottom from the blender base using a Phillips #2 screwdriver. Unscrew the 16mm screws located on the plastic bottom from the blender base using a Phillips #2 screwdriver.
  • Unscrew the 16mm screws located on the plastic bottom from the blender base using a Phillips #2 screwdriver.
Is it possible to get a replacement base. Just the plastic cover? I can't seem to find mine and it is cracked and broken yet still works.
Blendin life - Replica
Remove the plastic bottom from the base of the blender. Remove the plastic bottom from the base of the blender.
  • Remove the plastic bottom from the base of the blender.
Aggiungi Commento
Holding the center of the fan, grip the knob in the center of the top of the blender with a wrench and twist the wrench counterclockwise. Holding the center of the fan, grip the knob in the center of the top of the blender with a wrench and twist the wrench counterclockwise.
  • Holding the center of the fan, grip the knob in the center of the top of the blender with a wrench and twist the wrench counterclockwise.
Aggiungi Commento
Carefully remove the motor and fan from the base of the blender.
  • Carefully remove the motor and fan from the base of the blender.
Aggiungi Commento
Now, gently pull the white wire that is connected to the base and the motor. Be careful, as there is a spring behind the contact points, that might try to shoot out and hurt you. Be careful, as there is a spring behind the contact points, that might try to shoot out and hurt you.
  • Now, gently pull the white wire that is connected to the base and the motor.
  • Be careful, as there is a spring behind the contact points, that might try to shoot out and hurt you.
Aggiungi Commento
Now, turn the motor over, and remove the black wire from the motor. Again, be warned as the is another spring that wants to shoot out and hurt you here as well. Again, be warned as the is another spring that wants to shoot out and hurt you here as well.
  • Now, turn the motor over, and remove the black wire from the motor.
  • Again, be warned as the is another spring that wants to shoot out and hurt you here as well.
Aggiungi Commento
Now de-solder the yellow wire from circuit board. De-solder the wire following these instructions. Be careful, as there is another, black wire, nearby that you do not want to de-solder.
  • Now de-solder the yellow wire from circuit board. De-solder the wire following these instructions.
  • Be careful, as there is another, black wire, nearby that you do not want to de-solder.
Aggiungi Commento
Locate the four 11mm screws in the circuit board. Unscrew the four screws using the Phillips #1 screwdriver. Unscrew the four screws using the Phillips #1 screwdriver.
  • Locate the four 11mm screws in the circuit board.
  • Unscrew the four screws using the Phillips #1 screwdriver.
Aggiungi Commento
Desolder the circuit board from the base at the indicated point, following the directions by clicking here. Now separate the circuit board from the base.
  • Desolder the circuit board from the base at the indicated point, following the directions by clicking here.
  • Now separate the circuit board from the base.
Aggiungi Commento
You will see that the circuit board is still attached by a red wire and a black wire. Flip the circuit board back over and desolder at the indicated points following the directions given here. Flip the circuit board back over and desolder at the indicated points following the directions given here.
  • You will see that the circuit board is still attached by a red wire and a black wire.
  • Flip the circuit board back over and desolder at the indicated points following the directions given here.
Aggiungi Commento
Conclusione
Now your circuit board is ready to be replaced. To reassemble your device, follow these instructions in reverse order.
Dana
Membro da: 14/04/2014
602 Reputazione
5 Guide realizzate
Cal Poly, Team 12-37, Maness Spring 2014 Membro di Cal Poly, Team 12-37, Maness Spring 2014
CPSU-MANESS-S14S12G37
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 36
Tutti i Tempi: 1,867
