Introduzione
To replace the lens for the projector, this guide will assist you in removing the back casing of the body of the clock as well as the casing of the projector arm.
Hold clock so the screen is facing away from you. Using your thumbs, push up on battery cover to remove. With your other hand, pull down on the A/C Adapter jack to remove.
  • Hold clock so the screen is facing away from you.
  • Using your thumbs, push up on battery cover to remove.
  • With your other hand, pull down on the A/C Adapter jack to remove.
Aggiungi Commento
Remove batteries by pushing a battery toward the spring.
  • Remove batteries by pushing a battery toward the spring.
  • Lift battery out at an angle. Repeat with second battery.
Aggiungi Commento
Use a Phillips #00 Screwdriver to remove the four (4) screws from the back of the projection arm. Once screws are removed, lift the back up and off of the projection arm.
  • Use a Phillips #00 Screwdriver to remove the four (4) screws from the back of the projection arm.
  • Once screws are removed, lift the back up and off of the projection arm.
Aggiungi Commento
Use a Phillips #00 Screwdriver to remove two (2) screws from back of projection arm. Use a Phillips #00 Screwdriver to remove two (2) screws from back of projection arm.
  • Use a Phillips #00 Screwdriver to remove two (2) screws from back of projection arm.
Aggiungi Commento
Use a Plastic Opening Tool to pry open the front of the projection arm casing.  Start at the top of the projection arm. Once top is partially open, use a Spudger to pry at the side of the projection arm.
  • Use a Plastic Opening Tool to pry open the front of the projection arm casing. Start at the top of the projection arm.
  • Once top is partially open, use a Spudger to pry at the side of the projection arm.
Aggiungi Commento
Turn the clock on its side.  Slide the focus wheel forward with your thumb. The Projection Beam and Focus Wheel Component should now be free of Projection Arm. Hold the Component in one hand and lift the Projection Beam up and away from the Focus Wheel.
  • Turn the clock on its side. Slide the focus wheel forward with your thumb.
  • The Projection Beam and Focus Wheel Component should now be free of Projection Arm.
  • Hold the Component in one hand and lift the Projection Beam up and away from the Focus Wheel.
Aggiungi Commento
The Lens is attached to the Focus Knob and is now accessible for replacement purposes.
  • The Lens is attached to the Focus Knob and is now accessible for replacement purposes.
Aggiungi Commento
Apply tape to the lens for safe removal and prevention of injury.
  • Apply tape to the lens for safe removal and prevention of injury.
Aggiungi Commento
Detach the focus knob from the internal casing of the lens by removing the screw from the base of the focus knob grip. Pry apart the pieces of casing holding the focus knob in place and remove the knob.
  • Detach the focus knob from the internal casing of the lens by removing the screw from the base of the focus knob grip.
  • Pry apart the pieces of casing holding the focus knob in place and remove the knob.
Aggiungi Commento
Insert the spudger into the opening above the hinge on the side of the casing. Press down firmly until the case opens. Press down firmly until the case opens.
  • Insert the spudger into the opening above the hinge on the side of the casing.
  • Press down firmly until the case opens.
Aggiungi Commento
Pull apart the casing and gently slide lens from pocket. Be sure to replace with a concave lens.
  • Pull apart the casing and gently slide lens from pocket.
  • Be sure to replace with a concave lens.
Aggiungi Commento
Conclusione
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 25
Tutti i Tempi: 1,049
