Salta al contenuto principale
Optoma HD20 Fan Replacement
Cosa ti serve
  1. Optoma HD20 Fan Replacement, Disassembling Optoma HD20 Cover: passo 1, immagine 1 di 2 Optoma HD20 Fan Replacement, Disassembling Optoma HD20 Cover: passo 1, immagine 2 di 2
    • Twist the focal cap clockwise until it is fully extended.
    • Remove the focal cap by pulling it straight out.
  2. Optoma HD20 Fan Replacement: passo 2, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
  3. Optoma HD20 Fan Replacement: passo 3, immagine 1 di 1
    • Use a plastic opening tool to gently pry the top cover off of the device.
    • It is easier to pry off the cover from the back side just above the HDMI ports.
  4. Optoma HD20 Fan Replacement: passo 4, immagine 1 di 1
    • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
    • Remove the ribbon by disconnecting it from the main circuit board.
    • Lift up the clip holding it down and pull the ribbon out.
  5. Optoma HD20 Fan Replacement, Fan: passo 5, immagine 1 di 1
    • Peel off the tape that is holding the metal casing down.
  6. Optoma HD20 Fan Replacement: passo 6, immagine 1 di 2 Optoma HD20 Fan Replacement: passo 6, immagine 2 di 2
    • Use a Phillips #1 screwdriver to unscrew the nine 4.5mm screws.
    • Use a Phillips #0 screwdriver to unscrew the three 2.5 mm screws. This will allow you to remove the metal casing.
  7. Optoma HD20 Fan Replacement: passo 7, immagine 1 di 1
    • Remove the metal casing by lifting it up off of the circuit board.
  8. Optoma HD20 Fan Replacement: passo 8, immagine 1 di 1
    • Unplug the six wires stemming from the circuit board.
  9. Optoma HD20 Fan Replacement: passo 9, immagine 1 di 1
    • Use a Philips #1 screwdriver to remove the four 4.5 mm screws
  10. Optoma HD20 Fan Replacement: passo 10, immagine 1 di 1
    • Remove the three 4.5 mm screws using the Philips #1 screwdriver.
  11. Optoma HD20 Fan Replacement: passo 11, immagine 1 di 1
    • Remove the two 4.5 mm screws located on either side of the VGA/SCART port using a 5 mm nut driver. This will further release the plastic backing from the motherboard.
  12. Optoma HD20 Fan Replacement: passo 12, immagine 1 di 1
    • Slightly rotate the motherboard clockwise. This will prevent ports from getting caught on the plastic backing.
    • Lift the plastic backing to remove it.
  13. Optoma HD20 Fan Replacement: passo 13, immagine 1 di 1
    • Ensure all screws are removed
    • Lift up the motherboard and take out the metal container beneath it.
    • Do this very carefully as there is still one cable attached.
  14. Optoma HD20 Fan Replacement: passo 14, immagine 1 di 1
    • Unplug the white connector underneath the right side of the circuit board.
    • To remove, pinch both sides of the connector and pull it away from the circuit board.
  15. Optoma HD20 Fan Replacement: passo 15, immagine 1 di 2 Optoma HD20 Fan Replacement: passo 15, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove four 5 mm screws. This will release the fan.
  16. Optoma HD20 Fan Replacement: passo 16, immagine 1 di 2 Optoma HD20 Fan Replacement: passo 16, immagine 2 di 2
    • Pull the fan away from the metal housing unit.
    • Gently lift the fan up and out of the device. The fan is now removed.
Conclusione
Altre 6 persone hanno completato questa guida.
Trever
Membro da: 01/22/15
1.264 Reputazione
6 Guide realizzate
Cal Poly, Team 21-23, Maness Winter 2015 Membro di Cal Poly, Team 21-23, Maness Winter 2015
CPSU-MANESS-W15S21G23
4 Membri
6 Guide realizzate
6 Commenti
Very nice set of instructions! Excellent images and identification of items to remove. Thank you!
Graveyard Workshop - Replica
Do you know where to get this fan for replacement? Having trouble finding a parts list.
Sterling Grogg - Replica
Small fan is GB1245PKVX-8, large fan is KDE1285PTV1
Gyrovague -
I am trying to determine if the fan works or not. Should the fan come on when there is no bulb in the projector? I removed the bulb when it burned up and I am not sure whether it was due to a failed fan or simply the bulb.
merrill277 - Replica
Amazing! Thank you!!! Took a bit of effort to get the fan but in the end it worked like a charm!! Thank you for saving money!!!!
Mike Popov - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 43
Tutti i Tempi: 12,814
