Salta al contenuto principale
Optoma HD20 Air Filter Replacement
Cosa ti serve
  1. Optoma HD20 Air Filter Replacement, Disassembling Optoma HD20 Cover: passo 1, immagine 1 di 2 Optoma HD20 Air Filter Replacement, Disassembling Optoma HD20 Cover: passo 1, immagine 2 di 2
    • Twist the focal cap clockwise until it is fully extended.
    • Remove the focal cap by pulling it straight out.
  2. Optoma HD20 Air Filter Replacement: passo 2, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
  3. Optoma HD20 Air Filter Replacement: passo 3, immagine 1 di 1
    • Use a plastic opening tool to gently pry the top cover off of the device.
    • It is easier to pry off the cover from the back side just above the HDMI ports.
  4. Optoma HD20 Air Filter Replacement: passo 4, immagine 1 di 1
    • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
    • Remove the ribbon by disconnecting it from the main circuit board.
    • Lift up the clip holding it down and pull the ribbon out.
  5. Optoma HD20 Air Filter Replacement, Air Filter: passo 5, immagine 1 di 3 Optoma HD20 Air Filter Replacement, Air Filter: passo 5, immagine 2 di 3 Optoma HD20 Air Filter Replacement, Air Filter: passo 5, immagine 3 di 3
    • Carefully peel off each air filter from the device
    • Pull up on the air filter to remove it.
  6. Optoma HD20 Air Filter Replacement: passo 6, immagine 1 di 1
    • Remove the air filter from the device.
    • Try not to deposit dirt from the air filter into the inside of the device.
Conclusione
Trever
Membro da: 01/22/15
1.264 Reputazione
6 Guide realizzate
Cal Poly, Team 21-23, Maness Winter 2015 Membro di Cal Poly, Team 21-23, Maness Winter 2015
CPSU-MANESS-W15S21G23
4 Membri
6 Guide realizzate
Un commento
There were no filters where the photos indicate.
Michael - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 54
Tutti i Tempi: 12,029
