Salta al contenuto principale
Opening Tapco Link Series device
Cosa ti serve
  1. Opening Tapco Link Series device, Introduction: passo 1, immagine 1 di 1
    • Put the device in front of you, with the knob labels the right side up
  2. Opening Tapco Link Series device, Revealing Screws: passo 2, immagine 1 di 2 Opening Tapco Link Series device, Revealing Screws: passo 2, immagine 2 di 2
    • Pry the rubber off the top of the device
    • All the rubber
    • Use your fingernails, then pull with your bare hands. Do no use a heat gun or prying tool as they will damage the adhesive.
    • 5 screw holes will appear. Leave them alone for now.
  3. Opening Tapco Link Series device: passo 3, immagine 1 di 2 Opening Tapco Link Series device: passo 3, immagine 2 di 2
    • Look at the side of the device with the metal stand
    • Take a heat gun to the two small foam pads
    • You only need to pry off the halves on the top plastic shell
    • Put scraps of glossy paper on the foam pads to prevent them from sticking on again
    • Alternatively, if you do not mind sacrificing aesthetics, you may slice the foam pads down the middle as in the picture.
  4. Opening Tapco Link Series device: passo 4, immagine 1 di 2 Opening Tapco Link Series device: passo 4, immagine 2 di 2
    • Now remove the 5 Philips screws on top
  5. Opening Tapco Link Series device: passo 5, immagine 1 di 1
    • Simply lift off the top
    • No clips anywhere
  6. Opening Tapco Link Series device: passo 6, immagine 1 di 1
    • You could now lift out the whole innards
    • They are not attached to the bottom shell
    • No, the mess of glue is how it left the factory
Conclusione
Tobias
Membro da: 07/24/14
10 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 201
