Parti
Nessuna parte richiesta.
Remove the 2 screws from the bottom of the camera
  • Remove the 2 screws from the bottom of the camera
Aggiungi Commento
Remove the screw from the right side of the camera.
  • Remove the screw from the right side of the camera.
Aggiungi Commento
Remove the two screws from the left side of the camera
  • Remove the two screws from the left side of the camera
Aggiungi Commento
Separate the front casing from the back using a plastic opening tool, gently. Silver band and buttons will become loose when you remove the two pieces. Silver band and buttons will become loose when you remove the two pieces.
  • Separate the front casing from the back using a plastic opening tool, gently.
  • Silver band and buttons will become loose when you remove the two pieces.
Aggiungi Commento
Pull the silver bracket and buttons off of the camera Pull the silver bracket and buttons off of the camera
  • Pull the silver bracket and buttons off of the camera
Aggiungi Commento
Remove the 2 screws on the right side of the camera. Remove the 2 screws on the left side of the camera. Circuit ribbon is attached at the top-left of the camera. Be careful when separating the front and back of the camera.
  • Remove the 2 screws on the right side of the camera.
  • Remove the 2 screws on the left side of the camera.
  • Circuit ribbon is attached at the top-left of the camera. Be careful when separating the front and back of the camera.
  • Pull the camera apart into 2 separate pieces.
Aggiungi Commento
Flip up clip on circuit ribbon, carefully
  • Flip up clip on circuit ribbon, carefully
  • Detach the ribbon from the rear to the front and pull it out, gently.
Aggiungi Commento
You will be left with four major pieces
  • You will be left with four major pieces
Aggiungi Commento
Conclusione
Tracy Donovan
Membro da: 10/02/2012
13 Reputazione
1 Guida realizzata
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 367
