Salta al contenuto principale
Olympus D590 Motherboard Replacement
Cosa ti serve
  1. Olympus D590 Motherboard Replacement, Face Plate: passo 1, immagine 1 di 1
    • Remove five baseplate screws using a Phillips #00 screwdriver.
  2. Olympus D590 Motherboard Replacement: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Press and slide the battery cover retainer clip to the left. Use tweezers to lift the battery cover away.
  3. Olympus D590 Motherboard Replacement: passo 3, immagine 1 di 1
    • Remove the single screw from the battery housing using a Phillips #00 screwdriver.
  4. Olympus D590 Motherboard Replacement: passo 4, immagine 1 di 1
    • Using tweezers, lift the rubber plate to expose the ports.
  5. Olympus D590 Motherboard Replacement: passo 5, immagine 1 di 1
    • Remove two screws from the ports using a Phillips #00 screwdriver.
  6. Olympus D590 Motherboard Replacement: passo 6, immagine 1 di 1
    • Use a spudger to pry the faceplate away from the rest of the camera.
  7. Olympus D590 Motherboard Replacement: passo 7, immagine 1 di 1
    • To avoid disconnection of the connector line to the motherboard, use caution when pulling faceplate away from camera case.
    • Damage to the connector line will prevent the on/off power switch's operational function.
  8. Olympus D590 Motherboard Replacement, Motherboard: passo 8, immagine 1 di 1
    • Remove four screws holding the motherboard to the internal housing component using a Phillips #1 screwdriver.
  9. Olympus D590 Motherboard Replacement: passo 9, immagine 1 di 1
    • Be cautious of the wires attached to the motherboard.
    • Remove the motherboard from the internal housing component.
    • Do not completely lift the motherboard out with the wiring connected. The wires must be disconnected before proceeding. The next step will demonstrate disconnection process.
  10. Olympus D590 Motherboard Replacement: passo 10, immagine 1 di 3 Olympus D590 Motherboard Replacement: passo 10, immagine 2 di 3 Olympus D590 Motherboard Replacement: passo 10, immagine 3 di 3
    Compra
    • Use rounded tweezers to disconnect the three wiring strips from the motherboard.
    • Using sharp tweezers may tear wiring tape and wires.
    • Use gentle force when wiggling or pulling wiring tape and wires to disconnect from the motherboard.
Conclusione
Altre 2 persone hanno completato questa guida.
Sara
Membro da: 04/15/10
84 Reputazione
2 Guide realizzate
Cal Poly, Team 28-23, Regan Spring 2010 Membro di Cal Poly, Team 28-23, Regan Spring 2010
CPSU-REGAN-S10S28G23
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,782
