Introduzione
Removal of the front plate to get into the logic board, lens, etc.
Parti
Nessuna parte richiesta.
Flip camera so you are looking at the bottom.
  • Flip camera so you are looking at the bottom.
  • Unscrew all 5 base plate screws.
Aggiungi Commento
Lift open retainer clip by sliding the clip to the left and letting the clip pop up.
  • Lift open retainer clip by sliding the clip to the left and letting the clip pop up.
Aggiungi Commento
Unscrew the single screw located next to the battery slot.
  • Unscrew the single screw located next to the battery slot.
Aggiungi Commento
Turn the camera so that the USB, AV and DC in/out rubber plate it facing you.
  • Turn the camera so that the USB, AV and DC in/out rubber plate it facing you.
  • Lift the rubber plate exposing the ports beneath.
Aggiungi Commento
Unscrew the 2 screws next to the USB and AC ports.
  • Unscrew the 2 screws next to the USB and AC ports.
Aggiungi Commento
Use a flathead screwdriver or another flat opening tool to pry the faceplate from the whole device.
  • Use a flathead screwdriver or another flat opening tool to pry the faceplate from the whole device.
Aggiungi Commento
Pull off the faceplate to reveal the inside of the camera.
  • Pull off the faceplate to reveal the inside of the camera.
  • Be careful of the connector that goes from the faceplate to the motherboard . Disconnecting this line will cause the camera not not power on through the on/off switch anymore.
Aggiungi Commento
Conclusione
Katie
Membro da: 15/04/2010
25 Reputazione
3 Guide realizzate
Cal Poly, Team 28-23, Regan Spring 2010 Membro di Cal Poly, Team 28-23, Regan Spring 2010
CPSU-REGAN-S10S28G23
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,496
