Salta al contenuto principale
Olympus Camedia D560 LCD Screen Replacement
Cosa ti serve
  1. Olympus Camedia D560 LCD Screen Replacement, LCD Screen: passo 1, immagine 1 di 2 Olympus Camedia D560 LCD Screen Replacement, LCD Screen: passo 1, immagine 2 di 2
    • Unscrew all immediately visible screws on the body of the camera.
    • Locations (# of screws): Bottom of camera (3), left side near video port (2), under cover of USB slot (3), memory card slot (1).
  2. Olympus Camedia D560 LCD Screen Replacement: passo 2, immagine 1 di 3 Olympus Camedia D560 LCD Screen Replacement: passo 2, immagine 2 di 3 Olympus Camedia D560 LCD Screen Replacement: passo 2, immagine 3 di 3
    • Use the plastic opening tool to separate the back cover from the camera.
  3. Olympus Camedia D560 LCD Screen Replacement: passo 3, immagine 1 di 3 Olympus Camedia D560 LCD Screen Replacement: passo 3, immagine 2 di 3 Olympus Camedia D560 LCD Screen Replacement: passo 3, immagine 3 di 3
    • With the back plate off, locate two screws: one diagonal from the top left of the LCD screen and one diagonal from the top right of the LCD screen.
    • Unscrew both of these screws.
  4. Olympus Camedia D560 LCD Screen Replacement: passo 4, immagine 1 di 1
    • Flip the LCD screen over.
  5. Olympus Camedia D560 LCD Screen Replacement: passo 5, immagine 1 di 1
    • Undo the clip holding the ribbon cable that attaches the LCD screen to the motherboard.
  6. Olympus Camedia D560 LCD Screen Replacement: passo 6, immagine 1 di 2 Olympus Camedia D560 LCD Screen Replacement: passo 6, immagine 2 di 2
    • Unclip the plug attached to the red and white wires that connects the LCD screen to the motherboard.
  7. Olympus Camedia D560 LCD Screen Replacement: passo 7, immagine 1 di 3 Olympus Camedia D560 LCD Screen Replacement: passo 7, immagine 2 di 3 Olympus Camedia D560 LCD Screen Replacement: passo 7, immagine 3 di 3
    • The LCD screen housing should now be free of the camera.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,253
