Salta al contenuto principale
Oculus Rift Development Kit 2 Headset Motherboard Replacement
Cosa ti serve
  1. Oculus Rift Development Kit 2 Headset Motherboard Replacement, Eye Relief Adjustment Screw: passo 1, immagine 1 di 3 Oculus Rift Development Kit 2 Headset Motherboard Replacement, Eye Relief Adjustment Screw: passo 1, immagine 2 di 3 Oculus Rift Development Kit 2 Headset Motherboard Replacement, Eye Relief Adjustment Screw: passo 1, immagine 3 di 3
    • Remove front cover plate.
    • Unplug the USB and HDMI cables from the Oculus Rift DK2.
  2. Oculus Rift Development Kit 2 Headset Motherboard Replacement: passo 2, immagine 1 di 3 Oculus Rift Development Kit 2 Headset Motherboard Replacement: passo 2, immagine 2 di 3 Oculus Rift Development Kit 2 Headset Motherboard Replacement: passo 2, immagine 3 di 3
    • Remove the four 3/8" Phillips #0 screws from the inner portion of the headset.
  3. Oculus Rift Development Kit 2 Headset Motherboard Replacement: passo 3, immagine 1 di 2 Oculus Rift Development Kit 2 Headset Motherboard Replacement: passo 3, immagine 2 di 2
    • With the screws removed, gently pull the headband frame apart from the headset.
  4. Oculus Rift Development Kit 2 Headset Motherboard Replacement, Remove Lens: passo 4, immagine 1 di 2 Oculus Rift Development Kit 2 Headset Motherboard Replacement, Remove Lens: passo 4, immagine 2 di 2
    • With the Oculus facing up, twist the right lens clockwise and lift it out. Repeat for the left lens twisting counterclockwise instead.
  5. Oculus Rift Development Kit 2 Headset Motherboard Replacement, Headset Motherboard: passo 5, immagine 1 di 1
    • Using tweezers, carefully lift the four rubber plugs as shown. They are a bit snug and you may need to jiggle them free with the tweezers.
  6. Oculus Rift Development Kit 2 Headset Motherboard Replacement: passo 6, immagine 1 di 1
    • Remove the four 3/8" screws attaching the eyewear enclosure to the front casing.
    • Read the next step before removing the faceplate!
  7. Oculus Rift Development Kit 2 Headset Motherboard Replacement: passo 7, immagine 1 di 2 Oculus Rift Development Kit 2 Headset Motherboard Replacement: passo 7, immagine 2 di 2
    • Carefully separate the faceplate and the cover. Gently rest the cover plate on top of the faceplate as shown in the pictures.
    • Do not use excessive force when separating these two pieces. There is a delicate ribbon cable connected to each.
  8. Oculus Rift Development Kit 2 Headset Motherboard Replacement: passo 8, immagine 1 di 2 Oculus Rift Development Kit 2 Headset Motherboard Replacement: passo 8, immagine 2 di 2
    • Gently pull out the small side tabs on the ribbon cable connector as shown to release the cable.
    • Push the tabs away from you, with the headset oriented as pictured. Carefully slide the ribbon cable out.
    • The headset should now be two separate pieces.
  9. Oculus Rift Development Kit 2 Headset Motherboard Replacement: passo 9, immagine 1 di 3 Oculus Rift Development Kit 2 Headset Motherboard Replacement: passo 9, immagine 2 di 3 Oculus Rift Development Kit 2 Headset Motherboard Replacement: passo 9, immagine 3 di 3
    • Unscrew the three 1/4" Phillips #00 screws as pictured and use the tweezers to lift them out.
  10. Oculus Rift Development Kit 2 Headset Motherboard Replacement: passo 10, immagine 1 di 1
    • Lift the tape and gently pry up the video data ribbon cable using the plastic opening tool as shown.
  11. Oculus Rift Development Kit 2 Headset Motherboard Replacement: passo 11, immagine 1 di 3 Oculus Rift Development Kit 2 Headset Motherboard Replacement: passo 11, immagine 2 di 3 Oculus Rift Development Kit 2 Headset Motherboard Replacement: passo 11, immagine 3 di 3
    • Gently pry back the motherboard clips to release the motherboard. The motherboard should now lift free.
Conclusione
Altre 7 persone hanno completato questa guida.
Adam
Membro da: 01/20/15
661 Reputazione
4 Guide realizzate
Cal Poly, Team 18-5, Maness Winter 2015 Membro di Cal Poly, Team 18-5, Maness Winter 2015
CPSU-MANESS-W15S18G5
4 Membri
6 Guide realizzate
Un commento
hi.
you know where possible buy the new motherboard?
Szatmari Attila - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 2,449
