Salta al contenuto principale
OPPO N1 Home Button, Volume Buttons and SIM Card Tray Replacement
Cosa ti serve
  1. OPPO N1 Home Button, Volume Buttons and SIM Card Tray Replacement, Rear Case: passo 1, immagine 1 di 1
    • Insert the plastic opening tool into the crevice. The back cover is most easily opened by starting at this location.
  2. OPPO N1 Home Button, Volume Buttons and SIM Card Tray Replacement: passo 2, immagine 1 di 2 OPPO N1 Home Button, Volume Buttons and SIM Card Tray Replacement: passo 2, immagine 2 di 2
    • In the photo we rotated the phone ninety degrees counterclockwise.
    • Gently slide the plastic opening tool around the edge of the phone to release the back cover from the phone. You may hear some snapping noises as you release the back cover.
    • The rear case should then come free.
  3. OPPO N1 Home Button, Volume Buttons and SIM Card Tray Replacement, Home Button, Volume Buttons and SIM Card Tray: passo 3, immagine 1 di 1
    • Use tweezers to remove the home button.
  4. OPPO N1 Home Button, Volume Buttons and SIM Card Tray Replacement: passo 4, immagine 1 di 1
    • Use tweezers to remove the volume button.
  5. OPPO N1 Home Button, Volume Buttons and SIM Card Tray Replacement: passo 5, immagine 1 di 2 OPPO N1 Home Button, Volume Buttons and SIM Card Tray Replacement: passo 5, immagine 2 di 2
    • In the first photo we rotated the phone 180 degrees. Use tweezers to remove the SIM card tray.
    • The phone has been rotated in the second picture to show where the buttons are removed from.
    • Our home button is not the original home button and is a replacement piece.
Conclusione
Altre 4 persone hanno completato questa guida.
Joshua Stone
Membro da: 09/26/14
1.064 Reputazione
5 Guide realizzate
USF Tampa, Team 13-5, Staggers Fall 2014 Membro di USF Tampa, Team 13-5, Staggers Fall 2014
USFT-STAGGERS-F14S13G5
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 2,516
