Salta al contenuto principale
OPPO N1 Battery Replacement
Cosa ti serve
  1. OPPO N1 Battery Replacement, Rear Case: passo 1, immagine 1 di 1
    • Insert the plastic opening tool into the crevice. The back cover is most easily opened by starting at this location.
  2. OPPO N1 Battery Replacement: passo 2, immagine 1 di 2 OPPO N1 Battery Replacement: passo 2, immagine 2 di 2
    • In the photo we rotated the phone ninety degrees counterclockwise.
    • Gently slide the plastic opening tool around the edge of the phone to release the back cover from the phone. You may hear some snapping noises as you release the back cover.
    • The rear case should then come free.
  3. OPPO N1 Battery Replacement, Battery: passo 3, immagine 1 di 2 OPPO N1 Battery Replacement, Battery: passo 3, immagine 2 di 2
    • Remove the six 4mm long screws holding the motherboard in with the ph0 Phillips head screw driver.
  4. OPPO N1 Battery Replacement: passo 4, immagine 1 di 1
    • Use the tweezers or your fingers to remove the sliver plates.
  5. OPPO N1 Battery Replacement: passo 5, immagine 1 di 1
    • Remove the black plate with your fingers.
  6. OPPO N1 Battery Replacement: passo 6, immagine 1 di 3 OPPO N1 Battery Replacement: passo 6, immagine 2 di 3 OPPO N1 Battery Replacement: passo 6, immagine 3 di 3
    • Use tweezers or your fingers to pull up the connector tabs.
  7. OPPO N1 Battery Replacement: passo 7, immagine 1 di 2 OPPO N1 Battery Replacement: passo 7, immagine 2 di 2
    • Use the blue opening tool to carefully pry the battery from the sticky tape that attaches it to the device.
Conclusione
Altre 17 persone hanno completato questa guida.
Joshua Stone
Membro da: 09/26/14
1.064 Reputazione
5 Guide realizzate
USF Tampa, Team 13-5, Staggers Fall 2014 Membro di USF Tampa, Team 13-5, Staggers Fall 2014
USFT-STAGGERS-F14S13G5
3 Membri
8 Guide realizzate
4 Commenti
And where can I find that battery? What is the battery's id number? ebay doesn't show any. Just oppo n1 mini.
djkleinen - Replica
Hi bigupbattery.com has them cheapest I've found the number is part no blp557
simon watling -
@simon watling
Omg, so big thanks, man! You just saved many euros for me!
djkleinen -
How hard is it to pry the battery off the phone?
arkanista - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 56
Tutti i Tempi: 22,390
