Salta al contenuto principale
OLPC XO-4 Touch Screen Frame Replacement
Cosa ti serve
  1. OLPC XO-4 Touch Screen Frame Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the laptop upside-down, with the handle facing away from you.
  2. OLPC XO-4 Touch Screen Frame Replacement: passo 2, immagine 1 di 2 OLPC XO-4 Touch Screen Frame Replacement: passo 2, immagine 2 di 2
    • Pull the lock tabs towards the green outer edges of the laptop.
    • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
  3. OLPC XO-4 Touch Screen Frame Replacement: passo 3, immagine 1 di 2 OLPC XO-4 Touch Screen Frame Replacement: passo 3, immagine 2 di 2
    • Lift up on the middle of the battery to remove it from the device.
  4. OLPC XO-4 Touch Screen Frame Replacement, Screen Frame: passo 4, immagine 1 di 3 OLPC XO-4 Touch Screen Frame Replacement, Screen Frame: passo 4, immagine 2 di 3 OLPC XO-4 Touch Screen Frame Replacement, Screen Frame: passo 4, immagine 3 di 3
    • Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side.
    • Rotate the screen 180° and remove the other two screws.
    • You will have to put your screwdriver through the handle in order to reach the middle screw for both sides.
  5. OLPC XO-4 Touch Screen Frame Replacement: passo 5, immagine 1 di 3 OLPC XO-4 Touch Screen Frame Replacement: passo 5, immagine 2 di 3 OLPC XO-4 Touch Screen Frame Replacement: passo 5, immagine 3 di 3
    • Remove the green side panel by pressing down on the small green button on the top and sliding the panel up.
    • Repeat the step above for the panel on the other side.
  6. OLPC XO-4 Touch Screen Frame Replacement: passo 6, immagine 1 di 1
    • Be careful not to pull the bottom too far out because a ribbon cable is under the frame and can easily break.
    • Gently lift up the lower part of the frame and pull it down to free the screen frame.
  7. OLPC XO-4 Touch Screen Frame Replacement: passo 7, immagine 1 di 2 OLPC XO-4 Touch Screen Frame Replacement: passo 7, immagine 2 di 2
    • Lift the black connector and pull the ribbon cable out by the purple tab, freeing the frame.
Conclusione
Ji Kim
Membro da: 01/25/13
18 Reputazione
3 Guide realizzate
Cal Poly, Team 3-29, Amido Winter 2013 Membro di Cal Poly, Team 3-29, Amido Winter 2013
CPSU-AMIDO-W13S3G29
4 Membri
20 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 212
