Introduzione
This guide will show you how to access the wireless card in the OLPC X0 1.5. The wireless card allows access to the internet and interaction with other OLPCs.
Parti
Nessuna parte richiesta.
Place the laptop upside down with the handle away from you.
  • Place the laptop upside down with the handle away from you.
Aggiungi Commento
Slide the tabs out, towards the green edges,  to show the open lock symbol.
  • Slide the tabs out, towards the green edges, to show the open lock symbol.
    • The right tab will stay in place, but the left tab must be held in position while you remove the battery.
Aggiungi Commento
Lift the middle of the battery to remove it. Lift the middle of the battery to remove it. Lift the middle of the battery to remove it.
  • Lift the middle of the battery to remove it.
Aggiungi Commento
Turn the laptop so it is resting on its bottom. Open the laptop by rotating the green wings on the side up, then lifting the top half of the laptop. Rotate the top half of the laptop about 90 degrees.
  • Turn the laptop so it is resting on its bottom.
  • Open the laptop by rotating the green wings on the side up, then lifting the top half of the laptop.
  • Rotate the top half of the laptop about 90 degrees.
Aggiungi Commento
Turn the laptop upside down, so you can see the screws on the bottom of the top half. Remove the two 4mm screws with a Phillips #1 screwdriver.
  • Turn the laptop upside down, so you can see the screws on the bottom of the top half.
  • Remove the two 4mm screws with a Phillips #1 screwdriver.
  • Rotate the top half 180 degrees.
Aggiungi Commento
Rotate the top of the laptop 90 degrees, so that it is facing you again.
  • Rotate the top of the laptop 90 degrees, so that it is facing you again.
  • Slide the green pieces off the device. They should come off easily.
Aggiungi Commento
Pull down on the white screen cover. It does not require much force. Remove the screen cover. The game pad on the left sometimes falls during this step.
  • Pull down on the white screen cover. It does not require much force.
  • Remove the screen cover.
  • The game pad on the left sometimes falls during this step.
Aggiungi Commento
Unscrew the four 7.62mm Phillips #1 screws on either side of the screen. The screen is still connected by ribbon cables. You can damage the cables if you remove the screen before disconnecting the cables.
  • Unscrew the four 7.62mm Phillips #1 screws on either side of the screen.
  • The screen is still connected by ribbon cables. You can damage the cables if you remove the screen before disconnecting the cables.
  • Move the screen down a little to expose the ribbon cables.
Aggiungi Commento
Flip up the tab right under the middle top of the screen. Pull the black ribbon cable out of the socket. Pull the black ribbon cable out of the socket.
  • Flip up the tab right under the middle top of the screen.
  • Pull the black ribbon cable out of the socket.
Aggiungi Commento
Flip up the smaller tab under the left side of the screen. Remove the small cable to separate the screen from the rest of the laptop.
  • Flip up the smaller tab under the left side of the screen.
  • Remove the small cable to separate the screen from the rest of the laptop.
  • Gently remove the screen.
Aggiungi Commento
Remove the four 4mm Phillips #1 screws that hold the top cover to the case.
  • Remove the four 4mm Phillips #1 screws that hold the top cover to the case.
Aggiungi Commento
Close the lid and rotate the device 180°. Press firmly on the top two corners of the outside cover. Then slide it down, away from the antennas.
  • Close the lid and rotate the device 180°.
  • Press firmly on the top two corners of the outside cover. Then slide it down, away from the antennas.
Aggiungi Commento
Remove the five 4mm Phillips #1 screws securing the EMI shield to the motherboard. Gently lift up and remove the EMI shield.
  • Remove the five 4mm Phillips #1 screws securing the EMI shield to the motherboard.
  • Gently lift up and remove the EMI shield.
Aggiungi Commento
Gently remove the two antenna cables by lightly pulling the cable connectors up.
  • Gently remove the two antenna cables by lightly pulling the cable connectors up.
Aggiungi Commento
Remove the two 5mm Phillips #1 screws holding the wireless card to the motherboard. The wireless card will pop up at an angle.
  • Remove the two 5mm Phillips #1 screws holding the wireless card to the motherboard.
  • The wireless card will pop up at an angle.
Aggiungi Commento
Remove the wireless card by gently lifting it out of the socket.
  • Remove the wireless card by gently lifting it out of the socket.
Aggiungi Commento
Conclusione
Wei Xia
Membro da: 25/01/2013
518 Reputazione
5 Guide realizzate
Cal Poly, Team 3-28, Amido Winter 2013 Membro di Cal Poly, Team 3-28, Amido Winter 2013
CPSU-AMIDO-W13S3G28
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 339
