Unscrew the 7 6.4mm T5 Torx screws from back panel Use spudger to separate front and back panels Use spudger to separate front and back panels
  • Unscrew the 7 6.4mm T5 Torx screws from back panel
  • Use spudger to separate front and back panels
Aggiungi Commento
The green grill is not screwed in so it can be pulled right out. The green grill is not screwed in so it can be pulled right out.
  • The green grill is not screwed in so it can be pulled right out.
Aggiungi Commento
Remove the 6 6.5mm T5 Torx screws. Remove power wires. Peel back copper tape and remove black and white wires.
  • Remove the 6 6.5mm T5 Torx screws.
  • Remove power wires.
  • Peel back copper tape and remove black and white wires.
Aggiungi Commento
Once all cables are removed, pull the battery apparatus out.
  • Once all cables are removed, pull the battery apparatus out.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Andrew Barbanera
Membro da: 20/09/2014
318 Reputazione
2 Guide realizzate
USF Tampa, Team 1-1, Hickman Fall 2014 Membro di USF Tampa, Team 1-1, Hickman Fall 2014
USFT-HICKMAN-F14S1G1
4 Membri
6 Guide realizzate
For replacement batteries, are they 18650? Do I want flat top or button tops?
evan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 19
Tutti i Tempi: 3,133
