Introduzione
Make sure device is unplugged.
Remove slip mat from top of the platter.
  • Remove slip mat from top of the platter.
Aggiungi Commento
Remove platter by inserting thumbs in holes and slowly pulling up.
  • Remove platter by inserting thumbs in holes and slowly pulling up.
  • There will be some initial resistance.
Aggiungi Commento
Remove damaged belt which will be located below the platter.
  • Remove damaged belt which will be located below the platter.
Aggiungi Commento
Install new belt by securing it around the inner ring, located on the back of the platter.
  • Install new belt by securing it around the inner ring, located on the back of the platter.
Aggiungi Commento
Place a thumb in each hole.
  • Place a thumb in each hole.
  • You should be able to feel the rubber belt.
  • Gently pull the belt with each thumb, keeping the belt taut around the inner ring.
Aggiungi Commento
Secure platter back on turntable while keeping belt taut. Pull belt around motor spindle.
  • Secure platter back on turntable while keeping belt taut.
  • Pull belt around motor spindle.
  • Gently let go of belt.
Aggiungi Commento
Test turntable by spinning the platter.
  • Test turntable by spinning the platter.
  • There should be slight tension causing the platter to come to a stop.
Aggiungi Commento
Linea Traguardo
Nikolai
Membro da: 12/10/2011
161 Reputazione
5 Guide realizzate
Cal Poly, Team 17-14, Regan Fall 2011 Membro di Cal Poly, Team 17-14, Regan Fall 2011
CPSU-REGAN-F11S17G14
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 45
Tutti i Tempi: 2,876
