Introduzione
After many charging cycles, your battery can wear out and eventually lose its ability to hold charge. When that happens, you will need to replace the battery to keep using your Mifi.
Strumenti
Nessun attrezzo richiesto.
Parti
Remove the rear cover by pressing down on the cover and pulling it away from the device.
  • Remove the rear cover by pressing down on the cover and pulling it away from the device.
Aggiungi Commento
Place your finger on the back of the battery located near the edge of the device.
  • Place your finger on the back of the battery located near the edge of the device.
  • Push your finger into the battery and lift up to pop the battery out of the device.
Aggiungi Commento
Insert the new battery into the battery slot.
  • Insert the new battery into the battery slot.
  • Make sure to place the battery in with the white arrows facing inward.
Aggiungi Commento
Re-install the rear cover by placing the inward end in it's slot. Push down on the cover while sliding it into the slot to snap it back into place.
  • Re-install the rear cover by placing the inward end in it's slot.
  • Push down on the cover while sliding it into the slot to snap it back into place.
Aggiungi Commento
Conclusione
Charge your new battery and you are ready to use your Mifi again.
Carissah
Membro da: 15/04/2012
147 Reputazione
2 Guide realizzate
Cal Poly, Team 7-36, Maness Spring 2012 Membro di Cal Poly, Team 7-36, Maness Spring 2012
CPSU-MANESS-S12S7G36
5 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 672
