Introduzione
Connection problems may occur with this device due to a faulty or broken antenna. You can contact your service provider or search online to purchase a new antenna to replace. This guide give instructions on how to replace antenna.
Parti
Nessuna parte richiesta.
Remove the rear cover by pressing down on the cover and pulling it away from the device.
  • Remove the rear cover by pressing down on the cover and pulling it away from the device.
Aggiungi Commento
Place your finger on the back of the battery located near the edge of the device.
  • Place your finger on the back of the battery located near the edge of the device.
  • Push your finger into the battery and lift up to pop the battery out of the device.
Aggiungi Commento
Using a metal spudger, pry open the device around the seam between the front and back cover.
  • Using a metal spudger, pry open the device around the seam between the front and back cover.
  • It may be difficult to split apart, so use force with caution.
  • It may seem like you are breaking the device, but you will only be breaking the adhesive lining that keeps the device sealed.
Aggiungi Commento
Once the seal has been broken all the way around, open the cases using your hands.
  • Once the seal has been broken all the way around, open the cases using your hands.
Aggiungi Commento
To disconnect the antenna, pull up on the antenna's connection to the circuit board until it pops off.
  • To disconnect the antenna, pull up on the antenna's connection to the circuit board until it pops off.
Aggiungi Commento
Carefully pull out the antenna along the edge of the device.
  • Carefully pull out the antenna along the edge of the device.
  • There is adhesive applied to the antenna, so it may not easily detach.
Aggiungi Commento
Reconnect your new antenna to the circuit board in the same position described in step 3.
  • Reconnect your new antenna to the circuit board in the same position described in step 3.
Aggiungi Commento
Re-lay antenna around the edge and over the adhesive.
  • Re-lay antenna around the edge and over the adhesive.
  • The antenna can be fitted back into several small recesses along the groove that it was originally inside.
Aggiungi Commento
Apply double-sided stick tape to the inner top and bottom halves of the device along the seam that was previously unsealed. Snap the two halves together along the adhesive line to reconnect it as it previously was. Snap the two halves together along the adhesive line to reconnect it as it previously was.
  • Apply double-sided stick tape to the inner top and bottom halves of the device along the seam that was previously unsealed.
  • Snap the two halves together along the adhesive line to reconnect it as it previously was.
Aggiungi Commento
Conclusione
With a new antenna, your device should be transmitting a signal as expected. Keep in mind that you will need adhesive tape to keep the device firmly together.
Carissah
Membro da: 15/04/2012
147 Reputazione
2 Guide realizzate
Cal Poly, Team 7-36, Maness Spring 2012 Membro di Cal Poly, Team 7-36, Maness Spring 2012
CPSU-MANESS-S12S7G36
5 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 137
