Introduzione
If the device will not turn on or has a broken power switch, use this guide to replace the switch.
Parti
Nessuna parte richiesta.
Unplug popper.
  • Unplug popper.
  • Remove plastic lid by picking the lid up.
Aggiungi Commento
Flip the popper on its side.
  • Flip the popper on its side.
  • Remove the screws on the bottom with the Phillips #2 phillips head screwdriver.
  • There are seven screws on the base. Five screws on the perimeter (12mm Philips #2 screws) and two in the middle (15 mm Philips #2 screws).
Aggiungi Commento
Remove the base.
  • Remove the base.
  • Save the screws you took out of the bottom in a safe place. They will be needed to reattach the housing to the base.
  • Unscrew the two screws (10 mm Philips #2 screws) from the base.
  • Remove the base and set it aside for now.
Aggiungi Commento
Locate the power switch connected to the side of the housing. Carefully pinch the sides of the power switch.
  • Locate the power switch connected to the side of the housing.
  • Carefully pinch the sides of the power switch.
  • Push the power button up and out of the housing.
Aggiungi Commento
Now that the power switch is removed from the housing, you have to remove the wires connected to the power switch.
  • Now that the power switch is removed from the housing, you have to remove the wires connected to the power switch.
  • Use the plastic opening tool to gently pry the wires loose from the power switch.
  • The wires should pop easily out from the power switch.
Aggiungi Commento
Remove the power switch from the device.
  • Remove the power switch from the device.
  • You can now replace the power switch if necessary.
Aggiungi Commento
Conclusione
Dana Clarke
Membro da: 26/09/2012
26 Reputazione
6 Guide realizzate
Cal Poly, Team 16-57, Forte Fall 2012 Membro di Cal Poly, Team 16-57, Forte Fall 2012
CPSU-FORTE-F12S16G57
5 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 646
