Salta al contenuto principale
Nostalgia Electrics RHP-310 Motor Replacement
Cosa ti serve
  1. Nostalgia Electrics RHP-310 Motor Replacement, Power Switch: passo 1, immagine 1 di 1
    • Unplug the popper.
    • Lift the lid up to remove it.
  2. Nostalgia Electrics RHP-310 Motor Replacement: passo 2, immagine 1 di 1
    • Lay the popper on its side.
    • Remove the five 12mm Philips #2 screws around the perimeter of the base with the Phillips #2 screwdriver.
    • Remove the two 15mm Philips #2 screws in the center of the base with the Phillips #2 screwdriver.
    • Put the removed screws in a safe place, they will be needed later to reattach the housing to the base.
  3. Nostalgia Electrics RHP-310 Motor Replacement: passo 3, immagine 1 di 1
    • Flip the base over to view the interior of the base panel.
    • Unscrew the two 10 mm Philips #2 screws from the base panel.
    • Remove the base and set it aside.
  4. Nostalgia Electrics RHP-310 Motor Replacement: passo 4, immagine 1 di 2 Nostalgia Electrics RHP-310 Motor Replacement: passo 4, immagine 2 di 2
    • Locate the power switch connected to the side of the housing.
    • Pinch the sides of the power switch.
    • Push the power button up and out of the housing.
  5. Nostalgia Electrics RHP-310 Motor Replacement: passo 5, immagine 1 di 1
    • Remove the wires connected to the power switch that should be detached from the housing.
    • Gently pry the wires loose from the power switch with the plastic opening tool.
    • The wires should easily pop out from the power switch.
  6. Nostalgia Electrics RHP-310 Motor Replacement: passo 6, immagine 1 di 1
    • Remove the power switch from the housing unit.
    • You can now replace the power switch, if necessary.
  7. Nostalgia Electrics RHP-310 Motor Replacement, Replacing Housing: passo 7, immagine 1 di 2 Nostalgia Electrics RHP-310 Motor Replacement, Replacing Housing: passo 7, immagine 2 di 2
    • Gently remove the heating component from the popper.
    • Unscrew the four screws (11mm Philips #2 screws) that connect the white top to the housing.
    • Save the screws from this step. You will need them to connect the new housing to the white top.
  8. Nostalgia Electrics RHP-310 Motor Replacement: passo 8, immagine 1 di 1
    • Remove the white top from the housing.
  9. Nostalgia Electrics RHP-310 Motor Replacement, Replacing Fan: passo 9, immagine 1 di 1
    • Unscrew the three 10 mm Philips #2 screws that hold the heating component together.
    • Keep the screws in a safe place. You will need them to put the heating component back together.
  10. Nostalgia Electrics RHP-310 Motor Replacement: passo 10, immagine 1 di 1
    • Pull the heating component apart.
  11. Nostalgia Electrics RHP-310 Motor Replacement: passo 11, immagine 1 di 2 Nostalgia Electrics RHP-310 Motor Replacement: passo 11, immagine 2 di 2
    • Locate the fan.
    • Pull the fan off the motor.
    • Do not pull too hard or you will break the motor.
  12. Nostalgia Electrics RHP-310 Motor Replacement: passo 12, immagine 1 di 1
    • You can now replace the fan. If there is debris, clean it out.
  13. Nostalgia Electrics RHP-310 Motor Replacement, Motor: passo 13, immagine 1 di 2 Nostalgia Electrics RHP-310 Motor Replacement, Motor: passo 13, immagine 2 di 2
    • Use a Phillips #0 screwdriver to remove the two 2.5mm screws connecting the motor to the fan base.
    • Remember to keep the screws. You will need them to reassemble the popper.
    • Remove the motor from the fan base.
  14. Nostalgia Electrics RHP-310 Motor Replacement: passo 14, immagine 1 di 1
    • Un-solder the wires that are connected to the motor.
  15. Nostalgia Electrics RHP-310 Motor Replacement: passo 15, immagine 1 di 1
    • Replace the old motor by soldering the new motor to the circuit board.
Conclusione
Dana Clarke
Membro da: 09/26/12
50 Reputazione
6 Guide realizzate
Cal Poly, Team 16-57, Forte Fall 2012 Membro di Cal Poly, Team 16-57, Forte Fall 2012
CPSU-FORTE-F12S16G57
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,922
