Salta al contenuto principale
Nortel Networks i2004 IP Speaker Replacement
Cosa ti serve
  1. Nortel Networks i2004 IP Speaker Replacement, Back Cover: passo 1, immagine 1 di 3 Nortel Networks i2004 IP Speaker Replacement, Back Cover: passo 1, immagine 2 di 3 Nortel Networks i2004 IP Speaker Replacement, Back Cover: passo 1, immagine 3 di 3
    • Flip the phone over to view the back.
    • Remove the power and phone cords.
  2. Nortel Networks i2004 IP Speaker Replacement: passo 2, immagine 1 di 1
    • Remove the seven 8mm Phillips #2 screws.
  3. Nortel Networks i2004 IP Speaker Replacement: passo 3, immagine 1 di 2 Nortel Networks i2004 IP Speaker Replacement: passo 3, immagine 2 di 2
    • Lift up the back cover slowly because there are still wires attached to the circuit board.
    • Lifting the back cover should not require a lot of force; simply lift with your fingertips.
  4. Nortel Networks i2004 IP Speaker Replacement: passo 4, immagine 1 di 1
    • Disconnect the rubber piece by pulling it out of the slot, freeing the back cover completely.
  5. Nortel Networks i2004 IP Speaker Replacement: passo 5, immagine 1 di 2 Nortel Networks i2004 IP Speaker Replacement: passo 5, immagine 2 di 2
    • Remove the six 8mm Phillips #2 screws.
    • Pull the speaker phone cover straight up.
  6. Nortel Networks i2004 IP Speaker Replacement, Speaker: passo 6, immagine 1 di 1
    • Lift the speaker straight up.
    • The speaker may need to be slightly wiggled in order to loosen and remove.
  7. Nortel Networks i2004 IP Speaker Replacement: passo 7, immagine 1 di 1
    • Cut the red and white wires as close to the speaker as possible.
    • Wire cutters are preferred, but normal scissors are fine too.
  8. Nortel Networks i2004 IP Speaker Replacement: passo 8, immagine 1 di 2 Nortel Networks i2004 IP Speaker Replacement: passo 8, immagine 2 di 2
    • Solder wires to new speaker.
Conclusione
Elizabeth
Membro da: 01/21/12
160 Reputazione
3 Guide realizzate
Cal Poly, Team 10-35, Amido Winter 2012 Membro di Cal Poly, Team 10-35, Amido Winter 2012
CPSU-AMIDO-W12S10G35
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,123
