Salta al contenuto principale
Nortel Networks i2004 IP Buttons Replacement
Cosa ti serve
  1. Nortel Networks i2004 IP Buttons Replacement, Back Cover: passo 1, immagine 1 di 3 Nortel Networks i2004 IP Buttons Replacement, Back Cover: passo 1, immagine 2 di 3 Nortel Networks i2004 IP Buttons Replacement, Back Cover: passo 1, immagine 3 di 3
    • Flip the phone over to view the back.
    • Remove the power and phone cords.
  2. Nortel Networks i2004 IP Buttons Replacement: passo 2, immagine 1 di 1
    • Remove the seven 8mm Phillips #2 screws.
  3. Nortel Networks i2004 IP Buttons Replacement: passo 3, immagine 1 di 2 Nortel Networks i2004 IP Buttons Replacement: passo 3, immagine 2 di 2
    • Lift up the back cover slowly because there are still wires attached to the circuit board.
    • Lifting the back cover should not require a lot of force; simply lift with your fingertips.
  4. Nortel Networks i2004 IP Buttons Replacement: passo 4, immagine 1 di 1
    • Disconnect the rubber piece by pulling it out of the slot, freeing the back cover completely.
  5. Nortel Networks i2004 IP Buttons Replacement: passo 5, immagine 1 di 2 Nortel Networks i2004 IP Buttons Replacement: passo 5, immagine 2 di 2
    • Remove the six 8mm Phillips #2 screws.
    • Pull the speaker phone cover straight up.
  6. Nortel Networks i2004 IP Buttons Replacement, Circuit Board: passo 6, immagine 1 di 1
    • Remove the red and white wires from the rubber casing rim.
  7. Nortel Networks i2004 IP Buttons Replacement: passo 7, immagine 1 di 2 Nortel Networks i2004 IP Buttons Replacement: passo 7, immagine 2 di 2
    • Lift out the speaker and set it away from the tray that holds it.
    • Then remove the black plastic tray at the bottom by lifting it straight up.
  8. Nortel Networks i2004 IP Buttons Replacement: passo 8, immagine 1 di 1
    • Remove the two 8mm Phillips #2 screws.
  9. Nortel Networks i2004 IP Buttons Replacement: passo 9, immagine 1 di 2 Nortel Networks i2004 IP Buttons Replacement: passo 9, immagine 2 di 2
    • Pull the gray plastic casing away from the circuit board as you remove the clear, curved, plastic piece straight up.
  10. Nortel Networks i2004 IP Buttons Replacement: passo 10, immagine 1 di 3 Nortel Networks i2004 IP Buttons Replacement: passo 10, immagine 2 di 3 Nortel Networks i2004 IP Buttons Replacement: passo 10, immagine 3 di 3
    • There are three clips on the circuit board to un-clip.
    • Unclip both back black clips with your fingertips.
    • Push the middle black clip towards the bottom of the picture with a flathead screwdriver.
  11. Nortel Networks i2004 IP Buttons Replacement: passo 11, immagine 1 di 2 Nortel Networks i2004 IP Buttons Replacement: passo 11, immagine 2 di 2
    • There's a brown ribbon still attached to the circuit board and phone case, so don't pull the circuit board completely off just yet.
    • Lift the edge of the circuit board over the phone case and slightly up, so the bottom of circuit board can be viewed.
  12. Nortel Networks i2004 IP Buttons Replacement: passo 12, immagine 1 di 1
    • Push down each brown clip on either side of the brown metal strip using your fingertip.
    • Detach the circuit board from the brown ribbon.
  13. Nortel Networks i2004 IP Buttons Replacement: passo 13, immagine 1 di 1
    • Remove the clear rubber casing.
    • Be careful not to flip over the front phone casing or all of the buttons will fall out.
  14. Nortel Networks i2004 IP Buttons Replacement, Buttons: passo 14, immagine 1 di 1
    • Press the broken button from the front of the phone.
    • Remove the broken button through the back.
Conclusione
Cal Poly, Team 10-35, Amido Winter 2012 Membro di Cal Poly, Team 10-35, Amido Winter 2012
CPSU-AMIDO-W12S10G35
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,050
