Introduzione
If your Nook Tablet speaker assembly component is not working properly or is broken, this guide will take you through the process of taking apart the device down to the motherboard. Then you will replace the speaker assembly with a new speaker assembly to allow for proper functioning again.
Flip the Nook over.
  • Flip the Nook over.
Aggiungi Commento
Lift the flap that reads "Nook" to reveal the tape that is underneath. Remove the memory card if one is present. Remove the tape covering the round holes to reveal two T5 Torx screws.
  • Lift the flap that reads "Nook" to reveal the tape that is underneath. Remove the memory card if one is present.
  • Remove the tape covering the round holes to reveal two T5 Torx screws.
  • Remove the two T5 Torx screws securing the back cover.
Remove stickers covering T5 screws and remove screws
badbyz - Replica
Also, remove the mini SD card first or you may break it taking the back off.
54pontiac - Replica
Insert the flat end of a spudger between the front panel and the rear assembly. Though these photos show a screwdriver, use a spudger or plastic opening tool in order to prevent damage to the device.
  • Insert the flat end of a spudger between the front panel and the rear assembly.
    • Though these photos show a screwdriver, use a spudger or plastic opening tool in order to prevent damage to the device.
  • Use a spudger to lift the the back panel from the rest of the Nook.
Aggiungi Commento
Slide the spudger around the edges of the Nook to loosen the back panel. Slide the spudger around the edges of the Nook to loosen the back panel.
  • Slide the spudger around the edges of the Nook to loosen the back panel.
Aggiungi Commento
Pull the back panel off the Nook.
  • Pull the back panel off the Nook.
Aggiungi Commento
Remove the ten T5 screws from around the edges of the silver midframe. Remove the ten T5 screws from around the edges of the silver midframe.
  • Remove the ten T5 screws from around the edges of the silver midframe.
Aggiungi Commento
Using a spudger or plastic opening tool, carefully pry the screen bezel away from the silver midframe. Using a spudger or plastic opening tool, carefully pry the screen bezel away from the silver midframe.
  • Using a spudger or plastic opening tool, carefully pry the screen bezel away from the silver midframe.
Aggiungi Commento
Lift up the foam pad at the corner of the battery to reveal the battery connector. Use a spudger or plastic opening tool to disconnect the battery cable from the motherboard.
  • Lift up the foam pad at the corner of the battery to reveal the battery connector.
  • Use a spudger or plastic opening tool to disconnect the battery cable from the motherboard.
    • These photos show a screwdriver, but we recommend using a nonconductive tool like a spudger to prevent a potential short.
Aggiungi Commento
Lift up the foam that covers the power connector and volume connector.
  • Lift up the foam that covers the power connector and volume connector.
  • Disconnect the power and volume cables from their sockets on the motherboard.
Aggiungi Commento
Carefully lift the silver midframe away from the motherboard and display assembly. Carefully lift the silver midframe away from the motherboard and display assembly.
  • Carefully lift the silver midframe away from the motherboard and display assembly.
Aggiungi Commento
Using your hands pull the square speaker assembly component off the motherboard.
  • Using your hands pull the square speaker assembly component off the motherboard.
Aggiungi Commento
Now place the new speaker assembly component back in the same square location.
  • Now place the new speaker assembly component back in the same square location.
    • As Step 12 mentions, make sure to realign the speaker assembly correctly in the square.
Aggiungi Commento
Conclusione
Josh Fisher
Membro da: 26/09/2012
9 Reputazione
1 Guida realizzata
Cal Poly, Team 1-4, Propen Fall 2012 Membro di Cal Poly, Team 1-4, Propen Fall 2012
CPSU-PROPEN-F12S1G4
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,889
