Salta al contenuto principale
Nook HD+ Battery Replacement
Cosa ti serve
  1. Nook HD+ Battery Replacement, Remove the front frame: passo 1, immagine 1 di 3 Nook HD+ Battery Replacement, Remove the front frame: passo 1, immagine 2 di 3 Nook HD+ Battery Replacement, Remove the front frame: passo 1, immagine 3 di 3
    • Wedge the plastic opening piece underneath the bottom left hand corner of the front frame. Pry the frame off of the Nook.
  2. Nook HD+ Battery Replacement, Remove the screws: passo 2, immagine 1 di 2 Nook HD+ Battery Replacement, Remove the screws: passo 2, immagine 2 di 2
    • Remove every visible screw tying the chassis to the bottom frame using the T-4 attachment for the screwdriver in the iFixit screwdriver kit.
  3. Nook HD+ Battery Replacement, Remove the chassis: passo 3, immagine 1 di 1
    • Carefully remove center chassis from bottom frame.
  4. Nook HD+ Battery Replacement, Detach battery: passo 4, immagine 1 di 3 Nook HD+ Battery Replacement, Detach battery: passo 4, immagine 2 di 3 Nook HD+ Battery Replacement, Detach battery: passo 4, immagine 3 di 3
    • Detach the battery ribbon from the motherboard.
  5. Nook HD+ Battery Replacement, Remove the battery: passo 5, immagine 1 di 2 Nook HD+ Battery Replacement, Remove the battery: passo 5, immagine 2 di 2
    • Pry battery off of bottom frame using plastic opening tool.
  6. Nook HD+ Battery Replacement, Place new battery: passo 6, immagine 1 di 1
    • Apply glue to the bottom side of new battery. Re-insert new battery onto bottom frame and allow to dry. Follow steps in reverse to put nook back together.
Conclusione
Altre 12 persone hanno completato questa guida.
UMass Dartmouth, Team 2-3, Duarte Fall 2014 Membro di UMass Dartmouth, Team 2-3, Duarte Fall 2014
UMASSD-DUARTE-F14S2G3
5 Membri
10 Guide realizzate
5 Commenti
Does model affect battery type? The replacement battery was stated so I'm just curious
Jon - Replica
Where i can buy new battery, or any similar [6000 mAh] ?
Sebastian kukosh - Replica
Anyone have a lead on good batteries?
omarhani - Replica
clear directions, liked this guide
wandat100 - Replica
i have a Barnes and noble nook HD+ and how it won't charger at all.
Tina Brown - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 49
Tutti i Tempi: 9,498
