Salta al contenuto principale
Nokia XL Dual Sim Rear Camera Replacement
Cosa ti serve
  1. Nokia XL Dual Sim Rear Camera Replacement, Back Cover Removal: passo 1, immagine 1 di 1
    • You will first need to separate the back cover from the device.
    • Gently pry open each side of the device at the indicated locations. It is best to use a plastic opening tool or similar tool.
  2. Nokia XL Dual Sim Rear Camera Replacement, Battery Removal: passo 2, immagine 1 di 2 Nokia XL Dual Sim Rear Camera Replacement, Battery Removal: passo 2, immagine 2 di 2
    • Remove the back cover.
    • Use a plastic opening tool to lift the battery. Then, remove it.
  3. Nokia XL Dual Sim Rear Camera Replacement, Screen Separation part 1: passo 3, immagine 1 di 2 Nokia XL Dual Sim Rear Camera Replacement, Screen Separation part 1: passo 3, immagine 2 di 2
    • To access the inner components of the device, remove the various screws. Keep them separate, and organize them by size.
    • You will need a T5 Precision Torx screw driver to remove the screws.
    • The locations of the T5x3.4mm screws are indicated in the picture.
    • The locations of the T5x4.1mm screws are indicated in the picture.
  4. Nokia XL Dual Sim Rear Camera Replacement, Screen Separation part 2: passo 4, immagine 1 di 3 Nokia XL Dual Sim Rear Camera Replacement, Screen Separation part 2: passo 4, immagine 2 di 3 Nokia XL Dual Sim Rear Camera Replacement, Screen Separation part 2: passo 4, immagine 3 di 3
    • Use the plastic opening tool to gently pry the device apart.
    • There are flaps on both sides of the phone as indicated in the picture. This is what you will need to pry apart.
    • Please be cautious when opening the device. There are various connectors inside the device that must be handled with care.
  5. Nokia XL Dual Sim Rear Camera Replacement, System components: passo 5, immagine 1 di 1
    • Once the device is open, take note of all the components.
  6. Nokia XL Dual Sim Rear Camera Replacement, Camera Removal Pt. 1: passo 6, immagine 1 di 2 Nokia XL Dual Sim Rear Camera Replacement, Camera Removal Pt. 1: passo 6, immagine 2 di 2
    • With tweezers, gently release the rear camera motherboard connector.
  7. Nokia XL Dual Sim Rear Camera Replacement, Camera Removal Pt. 2: passo 7, immagine 1 di 3 Nokia XL Dual Sim Rear Camera Replacement, Camera Removal Pt. 2: passo 7, immagine 2 di 3 Nokia XL Dual Sim Rear Camera Replacement, Camera Removal Pt. 2: passo 7, immagine 3 di 3
    • Gently pull the motherboard connector upward to remove the rear camera component.
Conclusione
Shadeed Bilal
Membro da: 09/25/14
231 Reputazione
4 Guide realizzate
USF Tampa, Team 1-4, Brown Fall 2014 Membro di USF Tampa, Team 1-4, Brown Fall 2014
USFT-BROWN-F14S1G4
3 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 748
