Introduzione
Use this guide on your quest to becoming a "selfie master" by replacing a damaged or non-functioning front facing camera on your Nokia XL Dual Sim.
You will first need to separate the back cover from the device.
  • You will first need to separate the back cover from the device.
  • Gently pry open each side of the device at the indicated locations. It is best to use a plastic opening tool or similar tool.
Aggiungi Commento
Remove the back cover. Use a plastic opening tool to lift the battery. Then, remove it.
  • Remove the back cover.
  • Use a plastic opening tool to lift the battery. Then, remove it.
Aggiungi Commento
To access the inner components of the device, remove the various screws. Keep them separate, and organize them by size. You will need a T5 Precision Torx screw driver to remove the screws.
  • To access the inner components of the device, remove the various screws. Keep them separate, and organize them by size.
  • You will need a T5 Precision Torx screw driver to remove the screws.
  • The locations of the T5x3.4mm screws are indicated in the picture.
  • The locations of the T5x4.1mm screws are indicated in the picture.
Aggiungi Commento
Use the plastic opening tool to gently pry the device apart. There are flaps on both sides of the phone as indicated in the picture. This is what you will need to pry apart. Please be cautious when opening the device. There are various connectors inside the device that must be handled with care.
  • Use the plastic opening tool to gently pry the device apart.
  • There are flaps on both sides of the phone as indicated in the picture. This is what you will need to pry apart.
  • Please be cautious when opening the device. There are various connectors inside the device that must be handled with care.
Aggiungi Commento
Once the device is open, take note of all the components.
  • Once the device is open, take note of all the components.
Aggiungi Commento
With Tweezers, gently unsnap the front camera motherboard connector. The front camera component can now be gently removed. The front camera component can now be gently removed.
  • With Tweezers, gently unsnap the front camera motherboard connector.
  • The front camera component can now be gently removed.
Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Shadeed Bilal
Membro da: 25/09/2014
216 Reputazione
4 Guide realizzate
USF Tampa, Team 1-4, Brown Fall 2014 Membro di USF Tampa, Team 1-4, Brown Fall 2014
USFT-BROWN-F14S1G4
3 Membri
7 Guide realizzate
merci 1000 fois pour ce cite
zmohye - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 852
