Parti
Nessuna parte richiesta.
The first step is to remove the back cover off of the phone. To do this, place both your thumbs on the two top corners of the device and simply pop it off.
  • The first step is to remove the back cover off of the phone. To do this, place both your thumbs on the two top corners of the device and simply pop it off.
Aggiungi Commento
To remove the battery, simply use your finger to pry the battery out of its slot.
  • To remove the battery, simply use your finger to pry the battery out of its slot.
Aggiungi Commento
Inserting a new battery is as simple as lining up the gold connectors and sliding the battery in text-side down.
  • Inserting a new battery is as simple as lining up the gold connectors and sliding the battery in text-side down.
Aggiungi Commento
Remove the four 5.33mm T5 Torx screws which are located in the corners of the phone. Remove the seven 4.00mm T5 Torx screws that line the phone between the corners.
  • Remove the four 5.33mm T5 Torx screws which are located in the corners of the phone.
  • Remove the seven 4.00mm T5 Torx screws that line the phone between the corners.
Aggiungi Commento
To remove the screen from the motherboard, you will need to apply some force until you feel it snap off. If the connectors unhook themselves, don't worry. To remove the screen from the motherboard, you will need to apply some force until you feel it snap off. If the connectors unhook themselves, don't worry.
  • To remove the screen from the motherboard, you will need to apply some force until you feel it snap off. If the connectors unhook themselves, don't worry.
Aggiungi Commento
If the connectors are still attached, simply unhook them by lifting the top of the connector with your finger.
  • If the connectors are still attached, simply unhook them by lifting the top of the connector with your finger.
Aggiungi Commento
Use a spudger to disconnect the rear-facing camera ribbon cable connector from the motherboard. Remove the camera module by merely picking it up out of its housing slot. Remove the camera module by merely picking it up out of its housing slot.
  • Use a spudger to disconnect the rear-facing camera ribbon cable connector from the motherboard.
  • Remove the camera module by merely picking it up out of its housing slot.
Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
Avery Dorsey
Membro da: 21/01/2015
1.648 Reputazione
4 Guide realizzate
USF Tampa, Team 6-1, Brown Winter 2015 Membro di USF Tampa, Team 6-1, Brown Winter 2015
USFT-BROWN-W15S6G1
3 Membri
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 782
