Turn the phone over so the screen is face down.
  • Turn the phone over so the screen is face down.
Aggiungi Commento
Remove the back cover by locating the slit on the bottom of the phone and lifting up. Remove the back cover by locating the slit on the bottom of the phone and lifting up.
  • Remove the back cover by locating the slit on the bottom of the phone and lifting up.
Aggiungi Commento
Remove the battery by lifting it out of the device.
  • Remove the battery by lifting it out of the device.
Aggiungi Commento
Remove the two "L-shaped" antennas by unscrewing the following screws: Four screw M1 .4x5.0
  • Remove the two "L-shaped" antennas by unscrewing the following screws:
    • Four screw M1 .4x5.0
    • Two screw RF1 .4x4
  • In addition to unscrewing the screws, remove the B-Cover (which will fall right out without the screws).
Aggiungi Commento
You will now have two halves of the phone.
  • You will now have two halves of the phone.
  • Grab the half of the phone that has the keyboard on it
Aggiungi Commento
Remove the keyboard by unsnapping the frame and then lifting the pad out from the device.
  • Remove the keyboard by unsnapping the frame and then lifting the pad out from the device.
  • Place the key pad and cover to the side for the remaining steps.
Aggiungi Commento
Use a blue plastic opening tool lift the motherboard out of the back cover
  • Use a blue plastic opening tool lift the motherboard out of the back cover
Aggiungi Commento
Look at the bottom of the motherboard to find the:
  • Look at the bottom of the motherboard to find the:
    • USB Port
  • Once you've located the USB Port you can search online or call the manufacturer to replace it.
Aggiungi Commento
Conclusione
Troy Posey
Membro da: 13/03/2014
268 Reputazione
2 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 20
Tutti i Tempi: 1,501
