Start with the phone in the flipped open position.
  • Start with the phone in the flipped open position.
  • You must remove the sticker in the center, below the screen to reveal the center screw.
  • Use a T5 screwdriver to remove all three screws, loosening the front screen.
Aggiungi Commento
Flip the phone to the closed position and turn to the front screen. The front cover will now be loose enough for you to remove by grabbing the edges and lightly pulling the cover off.
  • Flip the phone to the closed position and turn to the front screen.
  • The front cover will now be loose enough for you to remove by grabbing the edges and lightly pulling the cover off.
Aggiungi Commento
With the front cover off, the screen and keypad should be loose.
  • With the front cover off, the screen and keypad should be loose.
Aggiungi Commento
Using a plastic opening tool pry up the cable connecting the LCD screen to the rest of the phone. With the cable disconnected, the screen should be free for removal or replacement.
  • Using a plastic opening tool pry up the cable connecting the LCD screen to the rest of the phone.
  • With the cable disconnected, the screen should be free for removal or replacement.
Aggiungi Commento
After removing the front screen and front keypad, your device should look like this.
  • After removing the front screen and front keypad, your device should look like this.
Aggiungi Commento
Using the T5 Screwdriver, remove the two screws shown. Using the T5 Screwdriver, remove the two screws shown. Using the T5 Screwdriver, remove the two screws shown.
  • Using the T5 Screwdriver, remove the two screws shown.
Aggiungi Commento
Make sure to remove the connection shown by gently easing the plastic opening tool underneath the connection and lightly prying the connection apart.
  • Make sure to remove the connection shown by gently easing the plastic opening tool underneath the connection and lightly prying the connection apart.
Aggiungi Commento
Gently, lift the board up to reveal the front screen. Gently, lift the board up to reveal the front screen.
  • Gently, lift the board up to reveal the front screen.
Aggiungi Commento
Using the plastic opening tool, lift and remove the inside screen. Using the plastic opening tool, lift and remove the inside screen. Using the plastic opening tool, lift and remove the inside screen.
  • Using the plastic opening tool, lift and remove the inside screen.
Aggiungi Commento
Conclusione
In order to install a new screen, simply follow the steps in reverse order with the new screen.
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 18-21, Garner Spring 2011 Membro di Cal Poly, Team 18-21, Garner Spring 2011
CPSU-GARNER-S11S18G21
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 16
Tutti i Tempi: 4,386
