Introduzione
You will need a Torx number 4 to complete this repair guide.
Parti
Nessuna parte richiesta.
Remove battery Remove battery
  • Remove battery
Aggiungi Commento
Using Torx number 4 unscrew the four  0.5mm screws.
  • Using Torx number 4 unscrew the four 0.5mm screws.
Aggiungi Commento
Push in four clips to detach the body.
  • Push in four clips to detach the body.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Separate the body into two pieces. Be careful not to damage the screen or body. Some force will be needed to separate the body. Be careful not to damage the screen or body. Some force will be needed to separate the body.
  • Separate the body into two pieces.
  • Be careful not to damage the screen or body. Some force will be needed to separate the body.
Aggiungi Commento
Remove the bottom piece that is clipped on. Some force will need to be exerted to remove the clip. Some force will need to be exerted to remove the clip.
  • Remove the bottom piece that is clipped on.
  • Some force will need to be exerted to remove the clip.
Aggiungi Commento
Using Torx number 4 unscrew the two 0.7 mm screws at the top of the device.
  • Using Torx number 4 unscrew the two 0.7 mm screws at the top of the device.
Aggiungi Commento
Once screws are removed detach back of phone from the motherboard. This will require some force and maneuvering. Be careful not to break phone back or motherboard.
  • Once screws are removed detach back of phone from the motherboard.
  • This will require some force and maneuvering. Be careful not to break phone back or motherboard.
Aggiungi Commento
Replace motherboard, ensure that replacement has the same serial number.
  • Replace motherboard, ensure that replacement has the same serial number.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Will Goldby
Membro da: 29/08/2011
184 Reputazione
4 Guide realizzate
Cuesta, Team 1-1, Zipperian Fall 2011 Membro di Cuesta, Team 1-1, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G1
3 Membri
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 2,682
