Salta al contenuto principale
Nokia E71x Battery Replacement
  1. Nokia E71x Battery Replacement, Battery: passo 1, immagine 1 di 2 Nokia E71x Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Use your fingers to lift the battery out of the phone.
Conclusione
Once the new battery is securely installed, you are ready to put your phone back together. Simply reverse the steps you followed to disassemble your Nokia E71x. Make sure all components fit snugly back into their places. Power on your device to ensure everything is working correctly. Congratulations on successfully replacing your battery! Your Nokia E71x should now be ready.
Will Goldby
Membro da: 08/29/11
187 Reputazione
4 Guide realizzate
Cuesta, Team 1-1, Zipperian Fall 2011 Membro di Cuesta, Team 1-1, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G1
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,097
