Introduzione
This guide shows you how to remove the motherboard so that you can access the internal components in case of needed replacement.
Parti
Nessuna parte richiesta.
Locate the button on the bottom of the back cover.
  • Locate the button on the bottom of the back cover.
Aggiungi Commento
Depress the button with your finger. While the button is depressed, slide the back cover off of the phone. While the button is depressed, slide the back cover off of the phone.
  • Depress the button with your finger.
  • While the button is depressed, slide the back cover off of the phone.
Aggiungi Commento
Grasp the top and bottom of the front cover. Grasp the phone body with your other hand. Lightly pull the casing off of the phone.
  • Grasp the top and bottom of the front cover.
  • Grasp the phone body with your other hand.
  • Lightly pull the casing off of the phone.
Aggiungi Commento
Lightly peel the keypad off of the phone. Lightly peel the keypad off of the phone. Lightly peel the keypad off of the phone.
  • Lightly peel the keypad off of the phone.
Aggiungi Commento
Locate the six star-shaped screws on the phone. Note: There are two on the bottom end, two in the middle, and two on the top end. Remove these screws using the screwdriver.
  • Locate the six star-shaped screws on the phone.
  • Note: There are two on the bottom end, two in the middle, and two on the top end.
  • Remove these screws using the screwdriver.
Aggiungi Commento
Grab the top and bottom of the phone casing. Carefully pull the motherboard apart from the bottom casing. The circuit board should be divided into two parts.
  • Grab the top and bottom of the phone casing.
  • Carefully pull the motherboard apart from the bottom casing.
  • The circuit board should be divided into two parts.
Aggiungi Commento
Grab the top and bottom of the remaining casing. Carefully pull apart the casing from the circuit board. Carefully pull apart the casing from the circuit board.
  • Grab the top and bottom of the remaining casing.
  • Carefully pull apart the casing from the circuit board.
Aggiungi Commento
The circuit board should be divided into three parts, completely separate from the back casing, as shown.
  • The circuit board should be divided into three parts, completely separate from the back casing, as shown.
Aggiungi Commento
Conclusione
Clinton
Membro da: 22/10/2012
57 Reputazione
14 Guide realizzate
Clemson, Team 14-5, Benson Fall 2012 Membro di Clemson, Team 14-5, Benson Fall 2012
CLEM-BENSON-F12S14G5
3 Membri
16 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 341
