Introduzione
The keypad may need to be replaced if the buttons on your phone are cracked. This guide will only instruct the user on how to replace the keypad interface, but will not actually replace the circuitry that allows the buttons to operate. Such a repair is covered in the Installing Nokia 8290 Circuit Board repair guide.
Strumenti
Nessun attrezzo richiesto.
Parti
Nessuna parte richiesta.
Locate the small button on the top of the phone. Depress the button. With your other hand, pull the front cover away from the phone.
  • Locate the small button on the top of the phone.
  • Depress the button.
  • With your other hand, pull the front cover away from the phone.
Aggiungi Commento
After removing the front cover, simply peel the keypad away from the front cover After removing the front cover, simply peel the keypad away from the front cover After removing the front cover, simply peel the keypad away from the front cover
  • After removing the front cover, simply peel the keypad away from the front cover
Aggiungi Commento
Conclusione
Clemson, Team 15-3, Benson Fall 2012 Membro di Clemson, Team 15-3, Benson Fall 2012
CLEM-BENSON-F12S15G3
3 Membri
21 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 258
