Introduzione
Installing a new antenna may be necessary if you are having trouble sending and receiving calls. Installation should only be done as a last resort, after trying all other possible solutions as listed in the Nokia 8290 Troubleshooting Guide. Installation requires no prior knowledge of mobile phone antennas.
Parti
Nessuna parte richiesta.
Locate the small button on the top of the phone. Depress the button. With your other hand, pull the front cover away from the phone.
  • Locate the small button on the top of the phone.
  • Depress the button.
  • With your other hand, pull the front cover away from the phone.
Aggiungi Commento
Remove all six 5.3 mm long T6 screws. Remove the circuit board/faceplate sub-assembly from the back of the phone. Take care to place screws in a safe location.
  • Remove all six 5.3 mm long T6 screws.
  • Remove the circuit board/faceplate sub-assembly from the back of the phone.
  • Take care to place screws in a safe location.
Aggiungi Commento
After removing the circuit board/faceplate sub-assembly, locate the antenna. Remove the antenna by prying it out with your fingers or a prying tool. It may help to turn the back portion of the phone over to allow the antenna to fall away. Remove the antenna by prying it out with your fingers or a prying tool. It may help to turn the back portion of the phone over to allow the antenna to fall away.
  • After removing the circuit board/faceplate sub-assembly, locate the antenna.
  • Remove the antenna by prying it out with your fingers or a prying tool. It may help to turn the back portion of the phone over to allow the antenna to fall away.
Aggiungi Commento
Conclusione
Clemson, Team 15-3, Benson Fall 2012 Membro di Clemson, Team 15-3, Benson Fall 2012
CLEM-BENSON-F12S15G3
3 Membri
21 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 301
